Old 23-06-2008, 12:15 PM   #1 (permalink)
Default Automatic logoff problem in xp
i have a lenova laptop with Windows xp professional.
recently, i installed avg antivirus 8.0 and completed a scan.
now when i boot the laptop i am getting the logon screen
but after logging in the computer automatically logs off
and comes back to the logon screen
what may be the problem?
please help
murphyker is offline
Old 23-06-2008, 12:22 PM   #2 (permalink)
Amir.php's Avatar
Default Re: Automatic logoff problem in xp
Seems while removing virus by AVG some infected system files also be deleted.
Take up your Windows xp professional CD and boot from it.
After booting choose a new installation on the same Drive in Which your XP installed.
This will check for any previous XP installation on this Drive First And Ask you to repair it.
After that your system should work fine.
Amir.php is offline
Old 23-06-2008, 12:30 PM   #3 (permalink)
thanks amir. let me try.
Old 23-06-2008, 12:50 PM   #4 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Better try to run it in Safe Mode if possible & then run SFC
Else Amir.php's thing will work 4 sure
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 23-06-2008, 03:19 PM   #5 (permalink)
Roadripper's Avatar
yeah sfc /scannow ll do the trick els do a system restore and c...
Roadripper is offline
Old 23-06-2008, 04:43 PM   #6 (permalink)
it is not getting into safe mode.
what is that sfc. can u be more clear?
sorry i am not an expert
Old 23-06-2008, 10:07 PM   #7 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
SFC stands for System File Checker.
In simple words it checks for all system files for errors.
To run it issue following command at command prompt
sfc /scannow
This will run SFC.exe.
Quiz_Master is offline
automatic logoff wi-fi? varunbhide QnA (read only) 2 12-03-2008 10:32 PM
How to change win logoff shortcut ?? prem4u Software Q&A 2 03-09-2007 11:34 AM
Automatic restart problem ra_sriniketan Software Q&A 1 28-07-2007 03:36 PM
Automatic Disconnection problem... go4saket QnA (read only) 1 03-02-2007 01:36 PM
No Logon or Logoff sound, Nikhilsam Software Q&A 2 01-07-2006 08:23 PM
- by chris
