Old 23-06-2008, 12:19 AM   #1 (permalink)
smile's Avatar
Angry Help Help Plzz Help?
Hi..... Guys
I have Youtelecom Brod band connection and speed is 96 K bps . The problem is when i enter any websites address it doesn't connected only after three to four times i refresh then it connects ....it happens both in IE & FF , I scan my system , reinstall Firefox , infact when i connect to my laptop i am not having any problem only with my PC . Please help me to solve my problem
SR
smile is offline
Old 23-06-2008, 12:26 AM   #2 (permalink)
slugger's Avatar
Default Re: Help Help Plzz Help?
you telecoms connections r down in mumbai at the moment
edit
did not read the PC-laptop thing
my bad
slugger is offline
Old 23-06-2008, 11:58 AM   #3 (permalink)
Amir.php's Avatar
I remember that few days ago you have post the same problem.
I think it is not your browser or system problem. I will be better for you to complain this problem to your service provider- Youtelecom.
Amir.php is offline
Old 23-06-2008, 02:01 PM   #4 (permalink)
smile's Avatar
Smile Re: Help Help Plzz Help?
Then how come its working well in my laptop
SR
smile is offline
Old 23-06-2008, 02:35 PM   #5 (permalink)
Amir.php's Avatar
I Think you have some problem to contact with your internet providers.
Well do a simple work. if in your home or any of your friend have modem+gprs enable mobile such as reliance, idea, airtel etc then try to make connection with your laptop.
assume data cable will provided by the mobiles.
if you have same problem then it will system problem otherwise you must report to your internet service provider.
good by.
Amir.php is offline
Old 23-06-2008, 02:45 PM   #6 (permalink)
Roadripper's Avatar
its a spyware cum adware which is blockin and is in the system 32 folder ... use SPybot + trojan remover + spywre doctor + nod32 ... this is wat i used and cleaned it.. it ll work out fine once ur done ...
Roadripper is offline
Old 23-06-2008, 03:35 PM   #7 (permalink)
Beta Waves's Avatar
Originally Posted by smile View Post
Hi..... Guys
Hello my dear smile you have posted the same problem here
Internet Help?
And again you have created a new thread ....
I am Back....
Beta Waves is offline
Old 23-06-2008, 05:13 PM   #8 (permalink)
smile's Avatar
Yep sorry , But there were no replies
SR
smile is offline
Old 25-06-2008, 06:41 PM   #9 (permalink)
g_goyal2000's Avatar
Maybe he has a DNS problem.
He may not have entered DNS server addresses in his desktop.
What say??
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 25-06-2008, 09:26 PM   #10 (permalink)
smile's Avatar
Unhappy Re: Help Help Plzz Help?
@ g_goyal2000 - I think i dont have DNS issue . My ip address is Obtain automically .If i had DNS problem then how come its working fine when i plug in my laptop and use internet
SR
smile is offline
Old 25-06-2008, 11:04 PM   #11 (permalink)
then try @Amir.php's method.
That surely will pin-point the problem.
Plzz help? smile Software Q&A 3 19-06-2008 03:27 PM
Plzz Help smile Software Q&A 2 13-11-2007 01:05 AM
Plzz help me !!! jasperjunnu Hardware Q&A 1 19-03-2007 12:44 AM
plzz tell me, how can...... sandeep bhatia QnA (read only) 2 30-11-2006 11:22 PM
Plzz help me hl2.. medigit Gamerz 6 24-03-2005 12:54 AM
- by chris
