Old 22-06-2008, 04:20 PM   #1 (permalink)
Default Help!!! Problem with autorun.inf
I'm fed up with this.....every time I insert my pen drive, this file is copied to it automatically......i tried changing the autorun script, deleting etc
nod32 and kaspersky are able to detect it but it is cmng again n again........
can anyone name the virus behind this????? I guess its a VB script, but I'm not able to find it.....
sarincv is offline
Old 23-06-2008, 01:02 PM   #2 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Default Re: Help!!! Problem with autorun.inf
Step 1 : Disable System Rstore (MyComp>Right Click>Properties)
Put avast yaar dats why its better than both of them
The on install it will ask for boot time scan (Click yes )
Restart PC
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 23-06-2008, 01:11 PM   #3 (permalink)
Amir.php's Avatar
Not sure but it may be kinza.exe
Amir.php is offline
Old 23-06-2008, 02:53 PM   #4 (permalink)
Roadripper's Avatar
i think its win32.autorun or may be babyface virus ..
Here is a way how to remove the infected Autorun.inf permanently:
  1. Boot your system in safemode
  2. Open your flash drive via command prompt (start>>run>>cmd.exe)
  3. Activate your flash drive (e.g. flash drive is in J:, just type Jn the command prompt - don’t forget to press enter)
  4. Type ATTRIB -H -R -S AUTORUN.INF then press “Enter”
  5. Restart ur PC and it work fine ....
Roadripper is offline
Old 23-06-2008, 03:28 PM   #5 (permalink)
Beta Waves's Avatar
After removing the hidden, read only and system attributes who will delete the file my dear friend
Execute this command after that
del autorun.inf
But if the virus is still in your comp or in any other comp to which you connect your pen drive you will get that again.
So update your antivirus and scan. Before scannig make sure you disable system restore. Also carry an antivirus scanner in your pendrive. There are many such kind of app
I am Back....
Beta Waves is offline
Old 23-06-2008, 03:32 PM   #6 (permalink)
Roadripper's Avatar
^^ yeah forgot to add that code ... lol thanks...then scan wit a nice anti....
Autorun.ini pritish_kul2 QnA (read only) 2 11-11-2007 06:10 PM
Problem with Autorun Disks CadCrazy Software Q&A 8 11-11-2006 08:02 AM
cd can't autorun in xp vraj_shani QnA (read only) 4 11-05-2005 11:57 PM
Autorun Gone... CD sourav QnA (read only) 5 02-05-2005 10:29 AM
autorun krishnansurya QnA (read only) 13 08-01-2005 01:50 PM
- by chris
