Old 19-06-2008, 11:37 PM   #1 (permalink)
ThE oNE & ONlY ??
mikeon's Avatar
Default How to share PPPoe connection through network ?
Hi I have a network at home which is presently ethernet but will be going wi-fi soon... it consists of a laptop running vista & a desktop running xp home... it is connected through a router through which I connect to BSNL dataone.The modem does have inbuilt pppoe dialling but I preefer to dial from the pc itself ad disconnet whn I please... my question is when auto dial in modem is on I can share the connection simultaneously on both pcs but when pppoe from pc is done I can connect only 1 at a time... how do I connect both by dialling from pc even when the other is connected ?I need to do this because I need the network on all the time but not the internet connection.
R.I.P 2pac, Biggie & Proof
Holla atcha' wherever you are !!!
mikeon is offline
Old 20-06-2008, 05:08 PM   #2 (permalink)
The Researcher
Default Re: How to share PPPoe connection through network ?
you may try a software called "analog proxy" and in the IE. make your conection shareable.
http://www.analogx.com/CONTENTS/down...work/proxy.htm
Ramakrishnan is offline
BSNL PPPOE Connection Missiong Ecko Broadband and DTH 2 14-04-2008 07:17 PM
pppoe connection ashishnehete Software Q&A 16 14-01-2008 05:22 PM
[Tut] Share Your Net Connection Over LAN theraven Tutorials 9 28-05-2007 11:17 AM
Create your own private network and share folders webgenius Tutorials 1 24-02-2007 01:45 AM
network laptop & desktop,also share a LAN Net wirelessly netneo Networking 2 19-06-2005 03:32 PM
