Old 18-06-2008, 06:58 AM   #1 (permalink)
nil_3's Avatar
Default Where to ACTIVATE audio input in Win Vista?
Whenever I want to record audio in my system, it says,
"The audio input is not activated. Recording audio is not possible. Please check your input configuration"
From where to ACTIVATE audio input. My OS is Win Vista Ultimate with SigmaTel Audio codec.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 18-06-2008, 09:38 AM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: Where to ACTIVATE audio input in Win Vista?
if you're using mic. for recording, make sure which mic. u using.
i.e., "connected to front of cabinet or back."
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 18-06-2008, 06:18 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
If its front, try putting it on the back. Your front cables might not be connected.
dheeraj_kumar is offline
Old 19-06-2008, 05:51 AM   #4 (permalink)
nil_3's Avatar
Actually I want to record something by playing it in my system itself, not from any external source with microphone. From where should I activate?
Intel 945GNT MoBo.
1GB RAM.
nil_3 is offline
Old 22-06-2008, 12:20 PM   #5 (permalink)
nil_3's Avatar
Somebody reply please. How can I ACTIVATE audio input in Win Vista? I want to record something by playing it in my system itself, not from any external source with microphone.
Intel 945GNT MoBo.
1GB RAM.
nil_3 is offline
Old 22-06-2008, 12:44 PM   #6 (permalink)
Krazy_About_Technology's Avatar
OK, heres what you should do. To record from the audio playing in your system, you must use the "Sereo Mix" device. Right click on the speaker icon in the system tray and choose Recording devices. In the dialog that opens up, there is a list of audio recording devices. There must be a mic device, a line in device at least. If stereo mix is not visible, right click on the list of devices, in the empty space somewhere and choose "show disconnected device" and "show disabled devices". This should show up Stereo Mix device besides many others like Aux etc. Now right click the streo mix device and choose Enable and then again choose "Set as default device". Now you are ready to go. Check the device's volume level and other properties by double clicking it. Then click OK to close the dialog.
Open up any recording program, for example, i use Audacity. Choose the stereo mix device for recording, whereever it is present. For Audacity its on the main interface as well as in the preferences menu.
I hope this will solve your query. Cheers!
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 23-06-2008, 07:16 AM   #7 (permalink)
nil_3's Avatar
Thanx a lot Krazy_About_Technology. Now I can do it. Thanx again!
Intel 945GNT MoBo.
1GB RAM.
nil_3 is offline
Old 24-06-2008, 02:50 AM   #8 (permalink)
^My pleasure buddy
Vista Audio Driver for DELL Gx 620 gunda_26 Software Q&A 2 02-05-2008 12:50 PM
Audio boost Vista Vaio legolas Software Q&A 2 23-09-2007 07:04 PM
5.1 audio ON VISTA NOT WORKING. lavi87 Software Q&A 1 08-08-2007 11:57 PM
No audio input! Chetan1991 Software Q&A 2 04-02-2007 02:35 PM
Vista Audio problem? shashank_re Software Q&A 12 21-11-2006 11:37 PM
- by chris
