Old 15-06-2008, 06:50 PM   #1 (permalink)
Senior Owner
_hsr's Avatar
Talking Mandriva not working...
The may edition of digit came with a copy of mandriva linux one iso.
I have a problem in using the distro. As reccomended, i burned the
image using alcohol120% software. Then, as usual, i booted into
the cd-rom. A blue screen with white font saying mandriva pops.
I select the boot mandriva option by pressing enter key. Blam !
a black screen comes and my cd-activity goes zero.... Even
after 1/2 hours, there is no change... Please help me with this
problem.
My system configuration is :
AMD Athlon 64 X2 4000+ processor
ASUS M2N MX motherboard
2GB DDR2 Zion ram
NVIDIA GeForce 8400GS graphics card
Hitachi 80GB IDE HDD
Sony DVD-RW (can also connect samsung DVD-ROM)
Also running Windows XP SP2
If at first you don't succeed; call it version 1.0
_hsr is offline
Old 15-06-2008, 06:57 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: Mandriva not working...
it may not be ISO issue.it can be due to your graphics card/Display resolution not detected by Mandriva install disk.
there are some options listed if your press F1,2 etc or look at the bottom of the screen when you first see the boot prompt "boot: " line.
praka123 is offline
Mandriva 2008 Tech_Wiz Open Source 15 23-11-2007 05:01 PM
Mandriva executioner Open Source 7 01-09-2006 10:35 PM
mandriva Official Techie Open Source 10 17-08-2006 07:18 PM
Help-Mandriva anvesh Open Source 4 05-07-2006 08:50 PM
