Old 11-06-2008, 01:16 AM   #1 (permalink)
Default TCP/IP Problem
Hello folks!
I have a very strange problem (sorry for this post being so long)
I have installed an application that creates some sort of VPN, which didn`t work (the application is virus-safe, that`s for sure). I restarted my pc, and I`ve seen that though till then the internet connection worked just fine, this time displayed the "limited or no conectivity" message.
I went to the connection properties and saw that Client for NetWare and 2 NWLink items were active in the general tab. When logging in, i`ve seen that the welcome screen was disabled and i got the win2000 login cassette.
I have uninstalled the 3 entries concerning NetWare and restarted. Didn`t solve my problem
I mention that TCP IP and everything that is usual for networking is still here and checked. TCP/IP is set on automatic to both ip and dns.
The ipconfig command replies an ip 169.254.a.b (255.255.0.0) with NO gateway. Moreover, the usual layout of ipconfig /all is
Autoconfiguration Enabled: yes
IP ADDRESS x
Netmask etc
This time, ipconfig /all replies
AUTOCONFIGURATION IP ADDRESS: 169.254.x.y (so one word more)
Adding to this, ActiveSync (which uses the tcp/ip protocol) reported that "TCP/IP Network Transport not installed".
I`ve reinstalled the driver for my NIC and reset the TCP/IP configuration using netsh int ip reset <logfile>
Didn`t solve my problem.
People at microsoft haven`t replied yet.... neither did my isp (still studying for the last couple of days)
I`ve used regedit and went to:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\Tcpip\Parameters
I`ve seen that when reinstalling my NIC, an entry like C5AED4-DE46-4BDC-etc is added into interfaces, and each time i reinstall my NIC another (new/random) key takes places to the old one. Let`s say that this time it`s
C5AED4-DE46-4BDC-etc (replaced further on by ***)
Into parameters, i`ve seen:
@Linkage: 3 entries concerning ***
@Adapters , at ***, keyName: Ipconfig value: tcpip\parameters\interfaces\***
@interfaces, at *** (here it gets interesting)
some keys (there are around 20-25):
DHCPClassIdAddress: 169.254.258.83
DHCPRetryStatys: 0
DHCPServer 255.255.255.255
DHCPNetMask 255.255.0.0
(I`ve exported the whole TCPIP registry section, i can post it here if u want to study it more)
I know not what to do next... I know the problem is around here, and it`s related to the netware... but it seems that reinstalling the NIC, resetting the tcp/ip does not solve my problem. Any ideas?
Thanks in advance!
shpid3r is offline
Old 11-06-2008, 10:42 AM   #2 (permalink)
Amir.php's Avatar
Default Re: TCP/IP Problem
follow the instruction in this thread:http://thinkdigit.com/forum/showthread.php?t=90011
Amir.php is offline
Old 11-06-2008, 10:53 AM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
^^ yeah, I think that suggestion will work here
dheeraj_kumar is offline
Old 17-06-2008, 03:18 PM   #4 (permalink)
Thank you for your suggestions, folks!
The problem wasn`t from .net suite. The application i`ve installed also added NetWare into the attributes of my net connection and that changed some of my internet settings: another IP, no DNS, another routing protocol.
I`ve contacted both my ISP and Microsoft, but they didn`t know what to say and asked for a couple of days to investigate.
Intrigued as I was because i could have made some minimal conectivity (set up a manual IP and ping some remote IPs - so, IPs, not DNS`s), I`ve tried to connect to my router (type in IE 192.168.0.1).
IE asked me to connect to the internet, I`ve chosen to connect and it reported some problem to TCP/IP protocol and hinted to go to Tools > Diagnose connection (from IE menus). I did that, deleted ALL connections and asked to scan for connections.
Reported (again) a problem with my TCP/IP and asked a restart to fix it. And it did.
Anyway I had located the problem into my registry, i simply didn`t know how to fix it...
shpid3r is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
