Old 10-06-2008, 11:27 PM   #1 (permalink)
Default blue screen problem....
sometimes blue screen comes out
writing "Error Memory Dump.."
computer will restart now
coputer hen restarts again
somebody tell me how to get rid of it
sumankalyan is offline
Old 11-06-2008, 12:07 AM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Wink Re: blue screen problem....
!!!!!!!BSOD!!!!!!!!!
Bahut din bad suna iske bare mein............
Dude u better fear it........
H/W: Check ur RAM settings better check its condition.......if its still working.........
If its alright check power cable connections and data bus connection.
S/W: any new s/w or drivers installed???? Uninstall and check??
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 11-06-2008, 12:09 AM   #3 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Default Re: blue screen problem....
Check the error code and message that's being displayed on the BSOD and mention it here.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is online now
Old 11-06-2008, 01:11 AM   #4 (permalink)
sabret00the's Avatar
need the BSOD error code bole toh....0x0xxxxxxxx for eg: 0x00000ED or 0xc0000218A etc... further... for basic troubleshooting mem dump issues...if the system starts back into windows the go to start > run > type "minidump" > whatever you find inside the folder delete the same...restart...this will buy you some more time for troubleshooting...get hold of the error code as I mentioned above...if youre confident then start googling with the code or if youre not then ask here...we'll help
C2D E6600,Asus P5N32 e SLI,1GB 667mhz,Samsung 940BW,Zeb 8600GT,Seagate 250GB sata II,16x Sony(OEM) dvd RW,Zeb Anitibiotic & Platinum 500W,Microsoft desktop pro 700,bluetooth,Logitech MX Revolution
sabret00the is offline
Old 11-06-2008, 01:12 AM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
A BSOD is caused due to malfunctioning/corrupted/conflicting drivers. So if you installed/reinstalled/uninstalled/updated any driver recently, you better check it.
dheeraj_kumar is offline
Old 11-06-2008, 09:05 AM   #6 (permalink)
this might also occur if ur product is corrupted...
just go to shop with warranty card and change the board or hard drive..which is actually causing the problem...BSOD(blue screen of death) is the fatal error and hard time error....so i suggesst u to take this problem seriously...in time!!
and i dnt think we can get rid of the problem...rather its something that is malfunctioning!!
good luck!!
chandal
chandal_keta is offline
blue screen problem Pepsi™ Hardware Q&A 1 10-05-2006 01:47 AM
Screen Goes Blue CT Squad QnA (read only) 2 07-04-2006 11:23 PM
Blue Screen Help naveen_reloaded QnA (read only) 5 25-11-2005 03:31 PM
Blue Screen shoegoe QnA (read only) 11 17-05-2005 10:07 AM
blue screen with info problem ArZuNeOs QnA (read only) 7 14-04-2005 05:09 PM
