Old 10-06-2008, 05:40 PM   #1 (permalink)
Default problem with internet explorer
hi i have a problem with my internet explorer, whenever i open it in the caption of the internet explorer i see about blank but no (microsoft internet explorer) but i see about blank followed by pc protected by shirke ghatkopar mumbai e, i have scaned my pc with virus scan and spyware scan but no results please help
nitinm is offline
Old 10-06-2008, 05:43 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: problem with internet explorer
Open regedit and goto:
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main
In right-side pane either delete "WindowTitle" key or change its value to whatever you want.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 12-06-2008, 05:04 PM   #3 (permalink)
No nothing is happening, i followed the given steps, i also deleted the registery i.e the
window title but it is getting reborn within 5 seconds!!! please help
nitinm is offline
Old 12-06-2008, 09:20 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
You've got a malware. Run the usual... NOD32, Spybot, Ad-Aware, HJT.
dheeraj_kumar is offline
Problem in Internet Explorer 7 cooldudie3 Software Q&A 12 29-03-2008 06:25 PM
Internet Explorer Problem sudipapd Software Q&A 2 12-08-2007 01:20 PM
internet explorer 7 problem saurabh kakkar Software Q&A 3 12-06-2007 11:32 PM
Internet Explorer 6.0 Problem- Plz Help !!! lovemeall26 Software Q&A 2 27-01-2007 12:47 PM
Problem with Internet Explorer sainit Software Q&A 3 24-09-2006 06:48 PM
