Old 09-06-2008, 11:04 PM   #1 (permalink)
Default a terrible problem in my system
i hav got windows vista home basic
my theme has changed to modified theme and vista standard theme is not present
when i play any audio file it says no driver installed
my antivirus is also not starting saying "firewall has stopped"
when i enable it nothing happens
in msconfig when i checked in services all services have been stopped
in task manager also no suspicious programs are running(i think so)
can someone tell me what to do?
sumankalyan is offline
Old 10-06-2008, 12:04 AM   #2 (permalink)
paranj
Posts: n/a
Default Re: a terrible problem in my system
re-install XP.
this is all i can say.
Old 10-06-2008, 12:07 AM   #3 (permalink)
pushkar's Avatar
Originally Posted by paranj View Post
re-install XP.
I think he means Vista.
@poster, did you do anything, like installed some software, after which these problems started?
pushkar is offline
Old 10-06-2008, 12:07 AM   #4 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
re-install XP.
WTF!!!!
As for the problem, u mentioned that in MSConfig, all services have been stopped. Put a checkmark against all of them and reboot. Try it n let us know if it helps.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is online now
Old 10-06-2008, 08:17 AM   #5 (permalink)
on rebooting
they remain stopped
Old 10-06-2008, 08:41 AM   #6 (permalink)
on rebooting
they remain stopped
haha i am new here but just want to tell u something to u guys...
umm i think u dnt know the advantage of using vista...and its realibilty!!
any problem simple...just give a cd and repair the windows and will be ready for u in a mins......
check this thread too...i found in forum.mazzako.com
http://forum.mazzako.com/index.php?topic=14998.0
thanks,
chandal
chandal_keta is offline
Old 10-06-2008, 11:46 AM   #7 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
on rebooting
they remain stopped
OK, then. Run services.msc and see if any services are disabled. Unless u hv or someone/something has meddled with them, they should not have 'Disabled' as their startup type. Set the startup type to 'Automatic' for such services and reboot.
Flickr!
Old 10-06-2008, 11:29 PM   #8 (permalink)
almost all the services have been stopped.
how to change all of the services 's startup type to automatic
Old 10-06-2008, 11:30 PM   #9 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
As I said before, click Start->Run, type services.msc and hit enter. Dbl-click any service's name and set the startup type.
Flickr!
Terrible problem!!!!!!!!!!!!!!! nkirad Reviews 6 04-12-2008 04:14 PM
I Did A Terrible Act - U Decide Its Bad Or Good techani Chit-Chat 30 06-05-2008 03:38 PM
system problem...... meghraj QnA (read only) 1 16-10-2007 06:57 PM
problem with my new system paul_007 Hardware Q&A 11 26-03-2007 10:04 PM
Terrible Problem!!!!!!!! tukaibatman QnA (read only) 2 08-11-2004 03:13 PM
