I have enugh memory evrythin ,space etc..1gb ram -160gb hard disk...The prob jus arised a week back...Now watever i put to download it stops after 5 sec it gives error message saying insufficient system resources..plz help
Re: utorrent-insufficient system resources prob?..
There might not be enough space on the drive you are downloading the file to. Check that.
