Old 09-06-2008, 06:06 PM   #1 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Default Help comp gone crazy......!
Dear friends
Help required again from your genius Brains
My lappy comp is suffering from the following problems:-
  • Whenever I start adobe acrobat it shows the application error. This error happens with several other programs like when I install vtp 8 and etc….
  • Another problem is whenever I try to open a link in ie6 it doesn’t open .
  • Last one is related to games whenever I run fifa 08 it runs at a very fast speed while playing the game (everything except in the menu )
NOTE: - I know it should have been posted in gamers segment but due to very very very slow speed it’s something next to impossible
skippednote is offline
Old 09-06-2008, 10:17 PM   #2 (permalink)
Cool Buddy's Avatar
Default Re: Help comp gone crazy......!
your comp is infected by virus. I have no solutions, infact i've been trying to figure if viruses can be cured at all, except for reinstalling windows
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 09-06-2008, 10:27 PM   #3 (permalink)
try scanning your comp with an av or antispyware. if this doesn't work then try repairing your windows.
abhijangda is offline
Old 10-06-2008, 06:58 AM   #4 (permalink)
Amir.php's Avatar
Your system is not infected by virus. your solutions are:
1. two solutins for acrobat:
1. temporary: use acrobat setup and run it. now choose repaire option.
2. parmanent: uninstall acrobat and install it again. choose custom install and now choose full installation or check all checkboxes.
note: you will face this problem because your installation type was minimum. in the minimum install only necessary files to run the acrobat will be installed. unfortunatly if any file miss or currupt, you will face this error many times.
2. for opening page in ie you need to configure it. if you are using proxy, set your ip address and port in ie setting. if problem persist write your error in detail. i will try to solve it.
3. check for other games. also write it clearly.
Amir.php is offline
Old 10-06-2008, 08:51 AM   #5 (permalink)
i agree with u totally bro..and full bakwas if virus it would rather stop functioning...like would give error or close application automatically without any msg............i think ur acrobat is old or some files maybe missing or deleted accidently...reinstall it....and try it...or i suggesst downlooad the lastest version of ACROBAT.....really good one!!
u can get it from the adobe professional site...good luck ahead!!
chandal
yes they can be healed what anti virus are u using....can u post...or i suggest u try using NOD32 is really good..cause if once u are affected with virus and if it has hit ur system...then just simple restarts and it will auto repair ur system and virus free again...umm work almost like DEEP FREEZE..however i think it has some defects too...coz sometimes at the same time..people might make their new folder and once u are caught by virus and u restart...and then BOOM....all are gone that u saved!! hehhehehe so for this reason i think kaspersky and good as it deals with most of the viruses...and AVG isnt bad either coz it can detect SPYWARE too in ur computer!!
good luck!!
chandal
Last edited by chandal_keta; 10-06-2008 at 08:55 AM. Reason: Automerged Doublepost
chandal_keta is offline
Old 10-06-2008, 08:58 AM   #6 (permalink)
hsr
Senior Owner
hsr's Avatar
actually, it is kinda a new virus. do a system restor to the previous day when you saw the problem. don't open any apps, just update your ativirus, and do a full system scan... it will be solved. Damn sure. about the fifa, you can change game speed by using an option in the game settings menu in my fifa (game speed = slow, normal, fast.
Ultimately, try increasing your resolution...
Read Rules > FAQs > Stickies before posting a new thread. PM me anytime for an issue, and I'll be idle on irc too.
My dream rig.
ლ(ಠ_ಠ)ლ Webchat for Digit.
hsr is offline
Old 10-06-2008, 09:07 AM   #7 (permalink)
M3TAL H3AD M3
Exclamation Re: Help comp gone crazy......!
The application error does not show up only with acrobat but also with several other programmes as well. The game problem occurs with all ea games like fifa and undying.
Note: My computer is highly protected from viruses; therefore no virus problems.
Thanks.
Old 10-06-2008, 09:27 AM   #8 (permalink)
Thanks.
i was sure not virus!!
umm i think its about ur graphic problem...umm try loading in the low memory in the game option...this should solve!! good luck
chandal
Old 10-06-2008, 12:53 PM   #9 (permalink)
Cool Buddy's Avatar
good luck!!
chandal
In my computer there is a virus named vundoo (I suppose, got that from google), random DLL files appear in system32 folder and they run through rundll32.exe. this process is shown in the task manager. teatimer shows that random files keep trying to add themselves to startup. Whenever this rundll32.exe starts the computer becomes very slow. None among avast, nod32, spyware terminator, spybot snd have been able to fix it. that is why i wrote that i think viruses cannot be repaired.
Nokia 5230 :(
Old 10-06-2008, 02:15 PM   #10 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Google for VundoFix.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is online now
Old 10-06-2008, 07:11 PM   #11 (permalink)
thanks for the knowledge.....
umm i wanted to know what is the effect of this virus...VUNDOO...does it replicates exe files iteself or does some other thing too...rather than WORMS??
umm i also have found rundll32.exe virus has some other names too like
1)W32.Miroot.Worm -
2)Backdoor.Lastdoor -
3)Trojan.StartPage
i found this when i googled.....around for rundll.exe
http://www.neuber.com/taskmanager/pr...dll32.exe.html
chandal
Old 10-06-2008, 08:38 PM   #12 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Rundll32.exe is pretty harmless, its just a component of windows, but its name, and its functionality are used by some malware. If rundll32.dll is asked to run a malicious dll, it would do so, and the antivirus would not detect the dll, but the host program(rundll32) thats why you get the alerts.
dheeraj_kumar is offline
Old 14-06-2008, 11:26 AM   #13 (permalink)
M3TAL H3AD M3
Unhappy Re: Help comp gone crazy......!
Dear friends
i think u are not gettin y problem so i posting a link
http://www.flickr.com/photos/25496413@N03/2577472424/of screenshot of the error and let me make it clear that the error persists with several other programs.I don't won't to reinstall windows unless it is too important.
I spit Rainbows.
Old 14-06-2008, 11:46 AM   #14 (permalink)
^^attachment doesn't work here
Faun is online now
Old 14-06-2008, 01:06 PM   #15 (permalink)
M3TAL H3AD M3
new link added instead of attachment.http://www.flickr.com/photos/25496413@N03/2577472424/
I spit Rainbows.
Old 14-06-2008, 05:45 PM   #16 (permalink)
1. Try reinstalling the programs which cause error.
2. NOD32, Spybot, Ad-Aware, HijackThis
3. Post the log here.
4. Run "sfc /scannow"
5. CCleaner - scan registry
6. Clean install windows.
Old 17-06-2008, 07:51 AM   #17 (permalink)
Amir.php's Avatar
Just a common solution......200% foober
Amir.php is offline
Old 17-06-2008, 12:57 PM   #18 (permalink)
and its just a common problem. He said nothing except many of his programs crash randomly. How else would you reply to that?
My Machine Got Crazy.... rtginc Chit-Chat 4 10-06-2008 07:14 PM
Help!!! CPU Multiplier gone crazy kanu2k7 Hardware Q&A 6 21-12-2007 04:40 PM
H'to conekt Off Comp with Home Comp abhijitroy QnA (read only) 2 22-01-2007 10:53 PM
outlook gone crazy manishji Software Q&A 3 26-08-2006 01:48 PM
My XP'S Gone Crazy beyondthegracefgod QnA (read only) 5 25-12-2004 09:59 PM
