i installed spiderman friend or foe. but it was not running beacause some visual c++ 2005 libraries were not installed. before i installed them i did some registry clean ups. Now i got those files installed and tried to run the game but it showed this error:"The procedure entry point _BinkGetFrameBuffersInfo@8 could not be located in the dynamic link library binkw32.dll" . the binkw32.dll file was version 1.5.x so i downloaded latest 3.x from net but the problem persists. plz help.
Install the runtime, and then the game again. Should do it.
