Old 03-06-2008, 08:49 PM   #1 (permalink)
ashisharya's Avatar
Exclamation Auto Shutdown
I want a program which can shut down da comp at a given time. it shud include hibernate option also n plz it shud work also. i have downloaded many programs but det all have failed my expectations.
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
ashisharya is offline
Old 03-06-2008, 09:54 PM   #2 (permalink)
Yalam
Default Re: Auto Shutdown
Have you tried DShutdown?
get it at http://digilander.libero.it/dimio/dshutdown.zip
Yavin is offline
Old 03-06-2008, 09:57 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Auto Power-on and shut down. from www.lifsoft.com
or
wake up on standby(can shut down hibernate etc too)
www.dennisbabkin.com/wosb
edit: dshutdown is slightly buggy for me, doesnt hibernate when I ask it to.
dheeraj_kumar is offline
Old 03-06-2008, 10:01 PM   #4 (permalink)
Genius in making mistakes
bhushan05d251's Avatar
u can run shutdown command frm command promp as well....jst see d "-t xx" parameter of it...u can set time @ xx in seconds....so if u want to shutdown ur comp after 5 minutes then execute this @ command window... "shutdown -s -t 300"......i dont think u r not aware of this.....lol...sorry for giving this silly knowledge....
bhushan05d251 is offline
Old 03-06-2008, 11:52 PM   #5 (permalink)
People know about that, its very popular knowledge too, except they use it only rarely.
Old 04-06-2008, 12:36 AM   #6 (permalink)
ashisharya's Avatar
thanx guys.....for ur help
To follow the path:
look to the master,
follow the master,
Old 04-06-2008, 02:41 AM   #7 (permalink)
Seed is the Life!!
shift's Avatar
start menu > run type at 11:45 shutdown -s
time is 24hr. 11:45 is 11:45 AM, 23:45 is 11:45 PM and so on
Stupidity Causes Cancer !!
shift is offline
Old 05-06-2008, 07:21 PM   #8 (permalink)
Lets Do It!
amrawtanshx's Avatar
Use Auto Power-on and shut down v 2.10
Its the most versatile of all shutdown softwares.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 06-06-2008, 10:49 PM   #9 (permalink)
aminsagar123's Avatar
smart sleep is good one too.
aminsagar123 is offline
Old 06-06-2008, 10:58 PM   #10 (permalink)
Here Since 2003
Indyan's Avatar
AMP WInoff is another option. It comes with loads of options.
Indyan is offline
Auto Shutdown after Firefox Downloads techtronic Internet & WWW 4 19-05-2007 12:56 AM
auto shutdown problem sidcool Software Q&A 1 29-05-2006 10:33 AM
Windows SHUTDOWN Problem, system freezez on shutdown screen catch_maxi Software Q&A 2 16-03-2006 07:38 PM
BEST AUTO-SHUTDOWN SOFTWARE?? sahil_blues Software Q&A 14 28-02-2006 10:52 AM
shutdown auto ?? CyCo QnA (read only) 4 02-02-2006 04:34 AM
