Old 03-06-2008, 12:59 PM   #1 (permalink)
Default help
I Iam using Kaspersky Antivirus 2009. Whenever I scan the system using the Antivirus & leave the system idle for sometime, suddenly all the desktop Icons disappear & I can only see my desktop background & after 20 seconds later the screen turns to Blue. Then I can see my user name & password. As I click my user name & password, It takes long time to go the desktop & also all the Icons flickers vigoursly. However this does not happen when I switch on the computer.
ronquad-alex231 is offline
Old 03-06-2008, 01:06 PM   #2 (permalink)
Seed is the Life!!
shift's Avatar
Default Re: help
Desktop > Right Click > Properties > Screen Saver > Power > Advanced >
uncheck Prompt for password when computer resumes from standby
Stupidity Causes Cancer !!
shift is offline
