Old 02-06-2008, 03:44 PM   #1 (permalink)
Smile please help me how to backup
Hi plz help me out how to back up my whole operating system which is installed in c drive and lot softwares,if i get any error are virus infect i must format the system and again i must install all the softwares which i cant do,so one of my friend told we can backup using norton ghost so any bady can help me out.
Thanking u
Hidayath
hidayath7 is offline
Old 02-06-2008, 04:05 PM   #2 (permalink)
Seed is the Life!!
shift's Avatar
Default Re: please help me how to backup
to back up :
1 download Hiren Boot Disc
http://www.hiren.info/pages/bootcd
2 burn to cd
3 insert the disc and boot from cd rom
4 select Disk Partitioning Tools
5 select Norton Ghost
6 select Partition > to image
7 select the partition you want to back up
8 select destination to store the image (backup)
9 wait till it complete
to restore :
1 boot using the disc u burnt
2 select Disk Partitioning Tools > Norton Ghost
3 select Partition > From Image
4 select the image u created before
the drive u want to back up and the location of the backup file cannot be same
ie. if u backup C, then save the backup to different drive
Stupidity Causes Cancer !!
shift is offline
Old 03-06-2008, 02:34 PM   #3 (permalink)
Thanku u very much i will try this
Thanku v much i will try this
Hello i have download the file of 100 mb but i cant make it bootable plz tell me how to make a bootable
what should I do to backup a webpage ?mainly backup of images from a blog. 56561 QnA (read only) 1 21-12-2007 09:41 PM
How Can I Backup Sms ? clmlbx Mobiles and Tablets 11 08-11-2007 11:00 AM
SMS Backup, is it possible? Shasanka_Gogoi Mobiles and Tablets 12 13-04-2007 09:07 PM
Backup !!!!!!!!!!!!!!! tehnogeek Software Q&A 1 25-02-2007 01:39 PM
registry backup means hd backup????? magnet QnA (read only) 3 01-04-2005 11:00 PM
