Hi friends,
I am dual booting XP pro and Vista Ultimate. XP pro is in my C drive and vista is in another drive. I want to format drive c and reinstall XP while keeping Vsta intact. Is this possible? if so how?
Thank You
www.harivarrier.com
Check out to earn money...
Format and re-install XP but I guess you willl need to boot using Vista's cd and then restore & fix the MBR
