Old 31-05-2008, 10:22 PM   #1 (permalink)
Rubik's Uncle!!
Charan's Avatar
Red face Sony Camcorder to PC
Hello guys, I borrowed my friends Sony Camcorder Model DCR-HC42E, I need to transfer the video from it to the PC, have the camcorder dock with me to connect it to the PC , but I do not have the software , I am unaware about which software to use for the purpose.
Vista detects it as Sony Camcorder, but windows movie maker cannot detect the cam. I will be thankfull if you guys help me get the software quick.
Thanks
Charan is offline
Old 01-06-2008, 02:37 AM   #2 (permalink)
Seed is the Life!!
shift's Avatar
Default Re: Sony Camcorder to PC
Use Ulead Video Studio 11. Its shareware but can use for 30 days
does your camcorder comes with PCI capture card?
Stupidity Causes Cancer !!
shift is offline
Old 01-06-2008, 06:31 AM   #3 (permalink)
jatt's Avatar
by which mean you want to capture dv on pc i mean are you using usb or firewire cable.
for editing and to capturing you can use pinnacle video studio is best.
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline
Old 01-06-2008, 07:06 AM   #4 (permalink)
The High 5 Flyer
sam9s's Avatar
To capture through a camcorder the best means is via firewire, your PC should have an inbuild firewire port else you can buy a firewire card for less than 400 bucks. For a brief explanation on video capturing kindly refer my below 2 threads. I hope the threads would clear some of your doubts.
Camcorder USB to Firewire to Video Capture/Editing: Possible?
IEEE 1394 Which one to buy 4 SAMSUNG Handy
sam9s is offline
Old 03-06-2008, 12:42 AM   #5 (permalink)
Rubik's Uncle!!
Charan's Avatar
First off sorry for the late reply. thanks for sharing the info.
I found that the camcorder wont work with vista. I have to use XP instead. The camcorder doc has a usb interface so im stuck with it, I dont have any interest in buying a firewire PCI card cause I just want to transfer three tapes. doesnt sony have its own video capture/transfer software?
On a second thought.. does any one convert the DV tapes to VCD/DVD for a fee? that will be great cause I dont have to do it myself. I dont mind spending 100-200 bucks/tape for the conversion
Charan is offline
Old 03-06-2008, 10:34 AM   #6 (permalink)
The High 5 Flyer
sam9s's Avatar
Ok you wana transfer via USB, you gotta make sue of two things.....your system has the USB 2.0 HIGH SPEED support coz except that you wont be able to transfer video. Second you have the handycamm drivers coz USB detection would require the drivers. Firewire on the other hand does not have any such problem, transfer speed is more than enough for a video and you dont need any drives for Firewire to work.
Sony does have their own capture applications but nobody uses it.......dunno why.....anyhow for capturing the best application if u did read my suggested post is WinDV, or if you dont want to WinDV for whatever reasons u can use the good old WMM embeded in XP itself. Finally I dont think anybody would convert DV Tapes for FREE unless you have a "jaan pehchaan". Most commercial photographes do this conversion business, charge anything between 200-500.....some charge even more. I on the other hand do it my self all the way from capturing, editing demuxing and creating the final DVD with my own choise of menus and background music.....
sam9s is offline
Old 03-06-2008, 11:24 AM   #7 (permalink)
Wire muncher!
infra_red_dude's Avatar
Uncle!! When did you return??
You can't transfer video via USB no matter. So unless you buy a firewire card, forget about transfering video.
AFAIK, USB can't be used to transfer video in DV camcorders, no matter what version of USB it is. USB is used only to transfer photos and/or use the camcorder as a webcam.
Uncle, you better buy a firewire cable (will cost about 150 bucks) and connect the camcorder to your laptop. You can use Windows movie maker to transfer video and burn DVD/VCDs.
infra_red_dude is offline
Old 03-06-2008, 01:06 PM   #8 (permalink)
The High 5 Flyer
sam9s's Avatar
Nope you can transfer video from USB, albeit with lot of hinderence, few I mentioned above.
Other being low quality (MPEG1) CIF Stream. You can even do a HQ DV transfer IF your camcorder supports DV transfer over USB 2. Only few camcorders do the HQ transfer over USB2 and that too with proprietary software and drivers supplied with the camcorder. If he is adament to use USB let him try, else yes FireWire is the most convenient and far better way to capture video. And now that its only 150 bucks these days, charan I think you should go for a firewire card, the cable comes along with it (I hope so coz may be just to cut the cost now they do not supply the cable)....... I got my card (for my old computer) for 400 bucks with the cable.
sam9s is offline
Old 03-06-2008, 03:09 PM   #9 (permalink)
Wire muncher!
Yes, only "some" camcorders support video over usb 2.0. And AFAIK none of the sony products do. Anyways, its worth a try.
BTW iirc his laptop has firewire. All he needs to get is a firewire cable with the mini-jack.
Old 03-06-2008, 11:47 PM   #10 (permalink)
Rubik's Uncle!!
Charan's Avatar
@sam9s first off .. I didnt mention I wanted the conversion for FREE.. I dont expect any work to be done for free.. All I wanted is professional work for a nominal fee
Thanks for your valuable feedback
Any way my laptop has firewire port the smaller tiny one .. I will buy the firewire cable as it might come in handy in future . its good to know that I dont have to have drivers for transfering via firewire
offtopic:
@Infra_red_kid...... I was alway here.. but no one knew abt it .. except one member
BTW is your secret still a secret? Stop calling me uncle or else the secret will be out .. Muhahahaha...
Charan is offline
Old 04-06-2008, 12:16 AM   #11 (permalink)
Wire muncher!
Yep, but the firewire with the mini connector. You should get it for 150-odd bucks at s.p.road.
offtopic:
Always there? Banned?! Whatever... husssshhh... not the secret, plz! I'll be a good kid now
Which camcorder is best to shoot in low light Cannon DC230 or Sony DCR-SR42 jaya QnA (read only) 1 02-12-2007 07:58 AM
Camcorder help,which of the two... harish_21_10 QnA (read only) 7 28-07-2007 01:45 PM
help me put regarding my camcorder please srikarv QnA (read only) 1 13-08-2006 11:47 PM
Sony Camcorder Tom Thomas QnA (read only) 5 20-12-2005 09:48 PM
which camcorder to buy? arclight QnA (read only) 11 09-06-2005 08:52 PM
