1. Open notepad
2. paste following lines into this:
[Autorun]
open=setup.exe
icon=setup.exe,0
3. Here setup.exe is the name of the .exe file which we want to autorun.
4. save it with the .inf extension on the same folder where your .exe file is exist(the .exe file which you want run automatically).
5.Now burn your entire folder on the CD/DVD.
After burning when you insert it into drive, the cd will run automatically with your specified .exe.
