Old 30-05-2008, 11:40 AM   #1 (permalink)
Ballack Junior
tuxybuzz's Avatar
Default Explorer not autostarting!!
i had this strange problem on my windows vista home basic laptop..everything seems fine untill the welcome screen..but after that there is just the blue screen..i start up the task manager and cant find explorer listed in the processes..so i start the explorer(new task) and everything turns normal..
any suggestions to fix this problem..
and yes another thing..vista doesnt allocate drives on its own to make restore points so i cant restore either..cause i have no restore points..
tuxybuzz is offline
Old 30-05-2008, 11:51 AM   #2 (permalink)
dhanusaud's Avatar
Default Re: Explorer not autostarting!!
insert Vista DVD, click start-Run
type sfc /scannow
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 30-05-2008, 02:15 PM   #3 (permalink)
Ballack Junior
tuxybuzz's Avatar
actually..this laptop came loaded with Vista..so i have no disk..the only option i have is the recovery manager..which first formats then reinstalls my laptop to the orignal cndition..
tuxybuzz is offline
Old 30-05-2008, 06:55 PM   #4 (permalink)
dhanusaud's Avatar
Oops...check if recovery dvds can do this. if not ***ate the same from ****ent sites.
Old 30-05-2008, 08:13 PM   #5 (permalink)
Ballack Junior
tuxybuzz's Avatar
umm..i dont think this is possible with the recovery disk..because whenever i boot it..it starts the recovery manager which has only one option to take the laptop to the original condition..
i think i will have to do that only..but the data will be lost..
tuxybuzz is offline
Old 31-05-2008, 12:19 AM   #6 (permalink)
dhanusaud's Avatar
you should backup your data before restoring OS, use linux livecd to do the same. it may help you to backup all of your data.
Old 31-05-2008, 01:09 AM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
I am not good with Vista............ But you can try "system restore".
Also, is your laptop of compaq?? If yes, than I think they have option to repair OS.
In recovery manager click on advance option-> than select OS repair.
ravi_9793 is offline
Old 31-05-2008, 07:57 PM   #8 (permalink)
Ballack Junior
tuxybuzz's Avatar
i think i forgot to mention..Ubuntu gusty is already installed on it..i will backup the imp data..but by data i actually meant the softwares and games i had installed..ill have to do that again..
n yes it is compaq..and ill see the OS repair..thanks all for your support..
i finally restored everything..its fine now..
tuxybuzz is offline
Explorer Gone?? rahul_u_know_me Software Q&A 2 14-05-2008 09:25 AM
Explorer.exe smile Software Q&A 14 03-12-2007 07:29 PM
Explorer smj Software Q&A 1 22-09-2006 12:18 PM
[Windows Explorer Prob.] Explorer opens each folder in a new window //siddhartha// Software Q&A 21 19-07-2006 01:24 PM
More Explorer Help sonuchandrakar Software Q&A 7 26-10-2004 03:49 PM
