Old 29-05-2008, 01:07 PM   #1 (permalink)
Question Re-Enable USB Port
Hey tech gurus
In my office, we have win xp with sp2. They have disabled the usb port for storage devices using a script. Usb mouse works fine though. I made some changes to the registry too, but didnt help...... any pointers?????
Wil;l shOOt ya!!
slask is offline
Old 29-05-2008, 01:40 PM   #2 (permalink)
dhanusaud's Avatar
Default Re: Re-Enable USB Port
follow these links, hope problem will be solved.
http://techinnews.blogspot.com/2008/...b-in-your.html
http://www.geekinterview.com/talk/24...usb-ports.html
USB ports can be enabled/diasbled through BIOS as well as Device Manager also.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 29-05-2008, 02:09 PM   #3 (permalink)
Unhappy Re: Re-Enable USB Port
Have tried the registry hack...doesnt work
Wil;l shOOt ya!!
slask is offline
Old 29-05-2008, 02:22 PM   #4 (permalink)
dhanusaud's Avatar
by the way your admin has used third party application to block usb for mass storage, see if there is any software like this & repost.
see if this link helps you.
http://labnol.blogspot.com/2006/07/h...ports-how.html
Old 04-06-2008, 04:02 PM   #5 (permalink)
hey,
thanks for the link......
no, my admin hasn't used any 3rd party sw....he's disabled it via scripts.... also, i noticed that he's restricted permissions to the usbstor.sys file in the root dir.....
any help????
Wil;l shOOt ya!!
slask is offline
How to enable DMA? godling Hardware Q&A 4 11-03-2007 06:50 PM
enable opacity.How ? LEARNER_LEARNER Open Source 8 06-01-2007 06:10 AM
How to Enable DMA mako_123 QnA (read only) 4 12-08-2006 12:20 AM
Broadband Modem: One USB port to Two USB port ajinkyakulkarni87 Hardware Q&A 3 03-08-2006 09:56 AM
Enable DMA in DVD drive guhanath Hardware Q&A 4 04-03-2006 03:17 PM
