Old 29-05-2008, 01:50 AM   #1 (permalink)
Question How to check the video and audio quality?
OS - Win XP SP2
PROBLEM - Suppose I download a video from the internet of Xvid Avi format, how can I know it's quality of audio and video. The problem is that one can stretch the actual video and make its size bigger. So, one may convert a DVD-quality video to an HD-DVD quality and then it will be hard to detect the difference by watching the video. So, is there any way to know the actual size of the video and actual bit-rate of the audio?
Udaya Maurya is offline
Old 29-05-2008, 05:23 AM   #2 (permalink)
Seed is the Life!!
shift's Avatar
Default Re: How to check the video and audio quality?
open with media player classic. SHIFT+F10 > Details
Stupidity Causes Cancer !!
shift is offline
Old 29-05-2008, 08:19 AM   #3 (permalink)
New
New's Avatar
U can also use GSPOT codec finding tool.. Which gives all the info about the file.
New is offline
Do you want to check the quality of your Mobile phone ajaykumarmeher Technology News 2 21-09-2007 11:52 PM
How to convert a video dvd into video cds without reducing quality arunks Software Q&A 4 21-09-2007 08:05 PM
Phone Camera Quality Check...[Bandwith Heavy]] Quiz_Master Mobiles and Tablets 1 22-04-2007 05:19 PM
Audio quality poorer in FC5 than SuSE phreak0ut Open Source 12 07-02-2007 09:41 PM
