Old 28-05-2008, 04:55 AM   #1 (permalink)
Red face Explorer not loading
After a reboot, I saw that the desktop was blank. I opened the task manager and saw that most of the processes had started, but explorer.exe had not, so I manually started it, but every time I start it, the desktop comes and then goes away after about seven to eight seconds. I have tried rebooting, system restore, and I found a method on google, something about checking the system files by typing sysscan or something in Start>Run, but nothing has helped. From what I have understood, the explorer shell has become corrupt, so is there any way to repair it?
Thanks.
HydraHeaded is offline
Old 28-05-2008, 10:08 AM   #2 (permalink)
dhanusaud's Avatar
Default Re: Explorer not loading
Insert XPCD & reboot your system, select Repair option when OS installation asks you to choose the appropriate option for your work done.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 28-05-2008, 10:12 AM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
its not sysscan.
its
sfc /scannow
dheeraj_kumar is offline
dvd not loading vicky_l7 QnA (read only) 6 05-07-2007 11:14 PM
os not loading rksingh Software Q&A 3 25-12-2006 07:45 PM
******bios Not Loading ****** soumendra Software Q&A 8 01-12-2006 05:26 PM
[Windows Explorer Prob.] Explorer opens each folder in a new window //siddhartha// Software Q&A 21 19-07-2006 01:24 PM
Problem with XP Loading vaibhav_vk QnA (read only) 4 18-10-2004 12:27 PM
