Old 26-05-2008, 06:57 PM   #1 (permalink)
Save the WORLD !!!
Kulz's Avatar
Default Plz help....
Hi everybody, i own a brand new DELL XPS M1530 laptop but sad to say is giving up some problems. Initially the laptop was not starting which got okay when the harddisk was replaced by Dell. And now its working perfectly ok except for a problem that when i start my system after say around an hour, it takes a lot of time in booting and finally a blue screen comes with a lot of things written ("your computer will be restarted so as to avoid any damage to the comp............"). Then it gets restarted and starts working perfectly ok. if i restart at this point,it does it normally. The blue screen and the self-restarting stuff happens everytime if the system is shut down for some time. Also sometimes a notification comes up when it gets started:-
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: 50
BCP1: 8A4C33FC
BCP2: 00000008
BCP3: 8A4C33FC
BCP4: 00000000
OS Version: 6_0_6000
Service Pack: 0_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\Mini052408-01.dmp
C:\Users\kulz\AppData\Local\Temp\WER-93538-0.sysdata.xml
C:\Users\kulz\AppData\Local\Temp\WER9EED.tmp.versi on.txt
Read our privacy statement:
http://go.microsoft.com/fwlink/?link...3&clcid=0x0409
The diagonostic has been run and no hardware problems have been found. Please if anyone could suggest me what has happened??? My configurations is as follows:
Intel core 2 Duo T8100 (2.1 Ghz,3MB cache, 800 Mhz FSB)
OS - Windows Vista Home Premium
3 GB 667 Mhz Dual Channel DDR2 SDRAM
250 GB SATA HDD
256 MB NVIDIA GEFORCE 8600M GT Graphics Card
Kulz is offline
Old 26-05-2008, 07:01 PM   #2 (permalink)
paranj
Posts: n/a
Default Re: Plz help....
now what u can do is re-install Vista and better if u move to XP or Ubuntu(best if u do that!) Next thing is to call Dell and yell at them abt ur problem. Vista is crap
