Old 22-05-2008, 11:22 PM   #1 (permalink)
Cool G5's Avatar
Post Motion capture software
I need a screen motion capture software to record videos showing some troubleshooting.
I need a software for this. It should be compatible with xp & vista.
Free is preferred.
Cool G5 is offline
Old 23-05-2008, 12:55 AM   #2 (permalink)
Seed is the Life!!
shift's Avatar
Default Re: Motion capture software
Quick Screen Recorder - Trial version, can use for 15 days
Stupidity Causes Cancer !!
shift is offline
Old 23-05-2008, 07:11 AM   #3 (permalink)
New
New's Avatar
Don't know free version.. Adobe Captivate will do your job..
New is offline
Old 23-05-2008, 07:59 AM   #4 (permalink)
dhanusaud's Avatar
ZD Soft's screen capture does a fantastic job too
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 23-05-2008, 09:12 AM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
www.techsmith.com
you can try their software.
dheeraj_kumar is offline
Old 23-05-2008, 08:13 PM   #6 (permalink)
TheSaint
NucleusKore's Avatar
Camstudio, I've used it, it's good
http://camstudio.org/
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 23-05-2008, 08:23 PM   #7 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Cool Re: Motion capture software
+1.. CamStudio
+2... CamStudio... Portable
Free... of course.... smile... it costs u nuthin.... (ur siggy said it... now do it...)
koolbluez is offline
Old 23-05-2008, 08:38 PM   #8 (permalink)
Cool G5's Avatar
Atlast free one...
Will try camstudio
Thanks everyone
Cool G5 is offline
Old 24-05-2008, 10:58 AM   #9 (permalink)
Linux Learner
PcEnthu's Avatar
Try Wink, its a feature rich, light weight one. Yes its a freeware
Its better ti keep your mouth shut and be thought as a fool, than to open and clear all doubts - [Source] Comments section of DistroWatch.Com
PcEnthu is offline
Old 24-05-2008, 04:50 PM   #10 (permalink)
dhanusaud's Avatar
hehehe. . . . does anybody has an idea to record music from screen saver as well as from keygens.
Old 24-05-2008, 05:47 PM   #11 (permalink)
Wise Old Crow
blueshift's Avatar
^ for that you have to record the sound that is playing on your PC. Google on how to do that.
I had tried Wink few years ago.. It has good features considering it's free.
http://twitter.com/blueshift155
blueshift is offline
Old 24-05-2008, 07:06 PM   #12 (permalink)
doing R&D of webtools
Lightbulb Re: Motion capture software
VidShot Capturer
CamStudio
Free Screen Capture
all are free screen capture software.
source
regards
Amit Shah
www.toolnext.com
amitshahc is offline
best screen capture software bukaida Software Q&A 5 23-10-2007 03:42 PM
pc slow motion entrana Software Q&A 9 24-07-2007 05:20 PM
Good software for DV capture? Anindya Software Q&A 9 24-06-2007 02:26 AM
Software to capture handycam video phreak0ut Software Q&A 5 11-12-2006 10:26 AM
SLOW MOTION GAMES satya Gamerz 6 09-01-2005 11:53 PM
