Old 22-05-2008, 06:52 PM   #1 (permalink)
digitoman's Avatar
Default Plz Help me with .avi file burning
Can anyone please tell me how to burn a downloaded .avi file onto a DVD or onto a CD in detail retaining the original quality and the best software for burning. Is it possible to burn the file onto CD or DVD as we make data CD or DVD?
digitoman is offline
Old 22-05-2008, 07:41 PM   #2 (permalink)
Formerly Spashy
Sparsh007's Avatar
Default Re: Plz Help me with .avi file burning
just copy the avi file onto the CD(Most players would play it that way)
The quality depends on the quality of the video downloaded nothing can change that
You can make a CD/DVD depending on the size
World Cup T20 News: http://wct20talk.com
Sparsh007 is offline
Old 22-05-2008, 09:46 PM   #3 (permalink)
New
New's Avatar
Yes... You can burn that .avi file on DVD or CD using softwares like nero, Ashampoo and cd burner XP without loosing the quality. What u need to do is just open the program and select "burn data CD/DVD". Do u want to play this on DVD player?
New is offline
Old 23-05-2008, 09:30 AM   #4 (permalink)
dhanusaud's Avatar
quality will be woooooorst. does anybody knows any software that won't effect quality of movie. i mean quality remains as it is.
don't suggest for burning dvds (i know it).
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 23-05-2008, 10:44 AM   #5 (permalink)
New
New's Avatar
Burning a file using nero will not decrease the quality.. What do u exactly want to do? Do u want to convert it before burning?
New is offline
Old 23-05-2008, 12:03 PM   #6 (permalink)
dhanusaud's Avatar
i wanna burn video cd with without effecting its quality.
Old 23-05-2008, 01:11 PM   #7 (permalink)
New
New's Avatar
AFAIK there's no good software than the nero as i mentioned earlier to burn your .avi file. I don't know why you are upset with it...
New is offline
Deleted an exe file suggest me a software for file recovery ranjan2001 Software Q&A 38 09-07-2008 05:34 PM
Difference between burning CD/DVD as MP3 Vs burning as DATA CD/DVD in Nero ajayritik Software Q&A 1 06-09-2007 07:33 PM
- Burning DVD to another DVD !! Dipen01 QnA (read only) 8 05-10-2006 04:34 PM
800 mb cd burning???? sirivishnu QnA (read only) 2 20-09-2005 09:56 AM
