Right click the executable of any dos app u want to run ( in ur case TC.exe).
Go to Properties
Select the Memory tab.
In Conventional Memory change both the settings to Auto
check the uses HMA box under Extended (XMS) Memory
Make the MSDOS protected mode to Auto
If this does not help, you can play around with the settings here, until u find a difference.
Also go to the compatibility tab and check Run this program in compatibility mode for Windows 95.
Hope these helps you.
My time machine will take you one hour into the future in only sixty minutes!
