Old 20-05-2008, 08:51 PM   #1 (permalink)
speedyguy's Avatar
Default Help: Change default my documents folder
i hv 2 explain this top 2 bottom 2 get appropriate response...
i had vista(installed wit lappy) in c drive...i created a d drive n installed xp over it...vista is useless nw....but as u know in vista default documents, music n videos folders r created inside a folder named as the username...
i hv large number of files in downloads, music, videos, documents etc which cannot b help in d drive of 20gb....is thr any way i can get my default pictures, downloads, documents etc frm c: as i specify fr this xp.....
thanx...
plz lemme knw if m not clear enuf...
Enjoy~!
No Pain...No Gain
speedyguy is offline
Old 20-05-2008, 09:56 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Help: Change default my documents folder
It is a feature in TweakUI, but its XP only. But there is an alternative called TweakVI which is released by www.totalidea.com Get the basic edition and check out the special folder location changing there.
dheeraj_kumar is offline
Old 20-05-2008, 11:09 PM   #3 (permalink)
speedyguy's Avatar
tweak vi is fr vista...i sed m runing on xp nw....got rid of vista....so wud i b goin fr tweak ui?
Enjoy~!
No Pain...No Gain
Old 21-05-2008, 04:41 AM   #4 (permalink)
Seed is the Life!!
shift's Avatar
Hope the attachment works
Stupidity Causes Cancer !!
shift is offline
Old 21-05-2008, 05:46 PM   #5 (permalink)
Yes, you have to go for TweakUI.
Old 21-05-2008, 06:10 PM   #6 (permalink)
Amir.php's Avatar
You can try this manual settings:
To change the default location of the My Documents folder, follow these steps: 1. Click Start, and then point to My Documents.
2. Right-click My Documents, and then click Properties.
3. Click the Target tab.
4. In the Target box, do one of the following:• Type the path to the folder location that you want, and then click OK. For example, D:\My Stuff.
If the folder does not exist, the Create Message dialog box is displayed. Click Yes to create the folder, and then click OK.
-or-
• Click Move, click the folder in which to store your documents, and then click OK twice.
If you need to create a new folder, click Make New Folder. Type a name for the folder, and then click OK twice.
5. In the Move Documents box, click Yes to move your documents to the new location, or click No to leave your documents in the original location.
Amir.php is offline
Old 21-05-2008, 09:49 PM   #7 (permalink)
speedyguy's Avatar
yes i worked it out already....twas just simple cut paste job 2 do....but one more thing...how can include an option in "save to", "download to" etc windows....if i want to include my pictures or my downloadds on left side suppose...the marked part
Enjoy~!
No Pain...No Gain
How to change Default "My Documents" location? arnold QnA (read only) 9 25-03-2008 01:15 PM
A file or a folder or My Documents????? technoraja Chit-Chat 1 22-07-2007 09:11 AM
change default documents folder in vista iMav Software Q&A 1 05-06-2007 12:29 AM
change Documents icon jampatana Software Q&A 1 23-10-2006 10:38 AM
Moving the Documents and Settings folder... thestrategist Software Q&A 7 28-05-2006 12:24 PM
