Old 20-05-2008, 10:41 AM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Unhappy Help!! windows xp problem
My XP has got some weired problem....
the local C,D drives r not opening when i
1.double click
2.ryt click >open
3.or ryt click > explore
when i do any of the above steps....a popup comes
open with...box (it has several programs list....) same as when u click a unknown
file....
they r opening only when i type the command thru "run"
i.e C:\my docs or D:\abc etc
wat is the problem...how shud i solve it
Zangetsu is offline
Old 20-05-2008, 11:47 AM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Help!! windows xp problem
start->run type "C:\" and delete the autorun.inf in each drive similarly. and then run a good virus scanner like nod32.
dheeraj_kumar is offline
Old 20-05-2008, 02:53 PM   #3 (permalink)
dhanusaud's Avatar
@dheeraj_kumar
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
windows XP problem maheshipw Software Q&A 13 24-09-2006 03:51 PM
Linux AV problem or windows AV problem?? thilina Open Source 2 02-09-2006 09:27 PM
windows 2000 and windows 98 problem swap_101982 Software Q&A 4 30-04-2005 12:04 AM
Problem in Windows XP sidadirat Software Q&A 1 09-01-2005 06:18 PM
