Old 18-05-2008, 07:13 PM   #1 (permalink)
aminsagar123's Avatar
Default Video Gurus. Please Help.
Hello Friends,
I have 4 DVDs of my friend's wedding. The total length of each DVD is no more than 2 hours.
I want to shrink videos from all the DVDs on a single DVD so i can play it on DVD player. Quality loss doesn't matter.
I have 6 VCDs of my cousin's wedding, i want to burn them all to a single DVD.
Please suggest a good software/tutorial to do these tasks.
Thanks a lot.
aminsagar123 is offline
Old 18-05-2008, 07:28 PM   #2 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Default Re: Video Gurus. Please Help.
To play on DVD player.... with no Divx/XVid reading capacity.... u have to maintain the "play duration".. meaning... total length of all dvds put together should be within 2 hrs.
We could have merged them all and put in a dvd with any video compression software but then.. it'll be unreadable in standard DVD players
Same for the VCDs...
Size/quality is relevant to compression standards and not standard video modes like VCD/DVD...
koolbluez is offline
Old 18-05-2008, 10:56 PM   #3 (permalink)
thanks. but see this thread >> How to Burn 4 Movies on 1 DVD
guy burned 4 movies on 1 DVD.
Old 18-05-2008, 11:10 PM   #4 (permalink)
Mad and Furious
redhat's Avatar
Use Nero Recode and try to compress the movies into 1 DVD
My new Tech Blog : http://technewspaper.blogspot.com/
redhat is offline
Old 18-05-2008, 11:21 PM   #5 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
its really really easy to do what you want.
First the burning the 6 VCDs to a dvd part: just place the video folders of each CD in the DVD. From what I know, a DVD has enough capacity to swallow 6 VCDs as a whole, without transcoding.
To place 4 DVD movies to one DVD, either transcode them to a format like h.264/vorbis in mkv and place them in the DVD, or use DVD Shrink or a similar software to reduce the size of each DVD movie, and then place them in the DVD.
But first, tell us if you intend to view them on a DVD Player or a PC.
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 19-05-2008, 12:18 PM   #6 (permalink)
@metalhead - want to play on DVD player.
call to all website designing gurus the.kaushik QnA (read only) 25 11-12-2007 12:30 PM
!!! Tricks Of Internet Gurus !!! go4saket Tutorials 6 08-03-2007 09:36 PM
Tweak gurus please help Mohnishgs Software Q&A 2 08-04-2006 09:47 PM
Any Linux Gurus here crorepathi Open Source 5 12-11-2005 12:18 AM
