Old 18-05-2008, 03:18 PM   #1 (permalink)
Default how to start the system automatically
hey guys is there a way to shut down the system automatically when the power goes off & start it when the power comes back again
ajith_yst is offline
Old 18-05-2008, 04:23 PM   #2 (permalink)
troubleshooter
bluepearl's Avatar
Default Re: how to start the system automatically
Check if your BIOS has options to switch ON with alarm
Also you can try modem triggered switch ON if u have always on connection !!
Could u be more specific with your question??
bluepearl is offline
Old 18-05-2008, 04:30 PM   #3 (permalink)
i want the system to turn off when the power goes out and start again when the power comes back again without any ones interruption
Old 18-05-2008, 11:34 PM   #4 (permalink)
Mad and Furious
redhat's Avatar
You need a UPS for that...
My new Tech Blog : http://technewspaper.blogspot.com/
redhat is offline
Old 19-05-2008, 08:14 AM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
If you have a UPS, and if it has a computer interface, you can control it from your comp. Then you could do what you asked.
dheeraj_kumar is offline
Old 21-05-2008, 04:16 AM   #6 (permalink)
Seed is the Life!!
shift's Avatar
Turn on Restore On AC Power Loss in your BIOS
This item specifies whether your system will reboot after a power failure or interrupt
occurs. Settings are:
[Off] Always leaves the computer in the power of f state.
[On] Always leaves the computer in the power on state.
[Last State] Restores the system to the status before power failure
or interrupt occurred.
Stupidity Causes Cancer !!
shift is offline
Old 21-05-2008, 04:37 AM   #7 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
either use a UPS, or make a circut for it yourself. But remember - the max it can do is to turn off power. Logging off or in needs drivers.
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 27-05-2008, 10:49 AM   #8 (permalink)
troubleshooter
bluepearl's Avatar
For shutting down on power failure u definitely need UPS.
As far as restarting when power comes back, it depends on your BIOS check if it has option to Switch on on power resume.
Do u have UPS, if positive u can configure it from Power Options in Control Panel to suite your needs !!
Old 08-06-2008, 11:53 AM   #9 (permalink)
i do have an ups when i try configuring it asks me to select a com port but my ups isnt connected to one must my ups be connected to a port?
Old 08-06-2008, 01:05 PM   #10 (permalink)
Obviously... do you expect your UPS to communicate with your computer via your power cord?
Need Help | I want to start my PC automatically when power comes the.kaushik QnA (read only) 25 08-01-2009 02:33 AM
System Restart Automatically !!! sauravktr QnA (read only) 6 12-11-2006 06:16 PM
System switches off automatically Natty Hardware Q&A 7 30-11-2005 10:42 AM
WHY DOES CHKDSK START AUTOMATICALLY slugger QnA (read only) 2 07-07-2005 09:51 AM
how to automatically start the pc for video recording? gsmsikar Software Q&A 12 31-12-2004 11:20 PM
