Old 17-05-2008, 01:00 PM   #1 (permalink)
Techtree Reviewer
krazzy's Avatar
Question Need help with gParted
I have a 40 GB HDD and have 3 partitions which use all the space on the HDD and there is no free unpartitioned space on the HDD. One of the partitions has around 8GB free space on it, so I was planning to take out 5GB from it without harming the data on that partition and create a new partition. People on Digit IRC told me to use gParted and so I downloaded the gParted iso and burned it on to a CD and booted from it. Upon booting I get these options:
http://i232.photobucket.com/albums/e...5/Image042.jpg
http://i232.photobucket.com/albums/e...5/Image043.jpg
Which one should I select??
Also after choosing the first option I only see my HDD but not the partitions in it.
http://i232.photobucket.com/albums/e...5/Image046.jpg
How to see the partitions???
krazzy is offline
Old 17-05-2008, 01:41 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Need help with gParted
Dont you have any OS installed? Try Ranish or Partition Magic if you are on Windows.
Pathik is offline
Old 17-05-2008, 05:11 PM   #3 (permalink)
Techtree Reviewer
krazzy's Avatar
^^ Aren't those paid software? I have Windows XP installed.
krazzy is offline
Old 17-05-2008, 05:16 PM   #4 (permalink)
Google Bot
Pathik's Avatar
Ranish is free. P Magic is *ahem* not.
Pathik is offline
Old 17-05-2008, 06:24 PM   #5 (permalink)
Techtree Reviewer
krazzy's Avatar
OK I tried Partition Magic (RS Zindabaad ), but something is wrong. After I made the required changes to the partitions and applied the changes, the PC restarts but the changes don't take place and the partitions are as they were before.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Pictorial for Gparted src2206 Tutorials 2 22-09-2007 05:58 PM
GParted Problem Vyasram Open Source 1 17-02-2007 09:13 PM
Gparted not Starting abhi_shake Open Source 6 29-11-2006 03:27 AM
