Old 16-05-2008, 01:07 AM   #1 (permalink)
bajaj151's Avatar
Default WindowBlinds not working with SP1
Stardock Windowblinds is not working with Vista SP1....Installation completes successfully but theme is not changing...
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard
bajaj151 is offline
Old 18-05-2008, 10:41 AM   #2 (permalink)
Seed is the Life!!
shift's Avatar
Default Re: WindowBlinds not working with SP1
Only full version of Stardock Windows Blind 5 and above works on Vista
Stupidity Causes Cancer !!
shift is offline
Old 18-05-2008, 12:39 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
+1.
get the latest 6.xx from the stardock site and then do it.
dheeraj_kumar is offline
Old 18-05-2008, 05:50 PM   #4 (permalink)
bajaj151's Avatar
I am facing this problem with Stardock Windowblinds latest version...which I downloaded (trial) from their site (www.wincustomize.com)
bajaj151 is offline
Old 17-06-2008, 07:52 PM   #5 (permalink)
bajaj151's Avatar
Problem Solved with New 6.01 version...
Thanks all 4 ur support...
bajaj151 is offline
WindowBlinds 5.5 Available! Third Eye Technology News 7 25-02-2007 04:43 AM
WindowBlinds 5.1 ax3 Software Q&A 28 14-12-2006 07:04 AM
WindowBlinds ! ! ! ax3 Software Q&A 19 07-02-2006 11:14 AM
WindowBlinds-Help!! Ravi+ish Software Q&A 21 25-12-2005 04:30 PM
WindowBlinds 4.51 Sourabh Software Q&A 8 09-04-2005 06:04 PM
