| Forum |
#1 (permalink) |
i hv cnnctd my lan wires as they were when i had winxp.. bt the internet icon in the system bar is showing a cross... i hv airtel broadband and a wi-fi router my setting is as follows..: 1.the phone line is into beetel 220bx modem 2.a lan wire from modem to wi-fi router 3. a lan wire from wi-fi to computer now the computer is showing as if thre is no connection with any lan wire... while i can access the internet on my laptop thru wi-fi...!! so tht means the internet actually is working bt windows vista isnt able to recog the internet smehw.. iam afraid if im missing on the lan card driver bt tht is nt available on my motherboard cd my mother board is nvidia 7050. wat do i do???? pls help Last edited by magneticme200; 16-05-2008 at 07:44 AM. |
#2 (permalink) |
TechTin.com
look into device manager, if your LAN card is properly installed.If not, install LAN driver.If you dont have LAN driver follow this:
1) connect to internet through USB. 2) Now in device manager, right click LAN adapter and select update driver, and than select search internet. 3) Vista will automatically find the driver.
www.9zap.com/forums -> Indian Webmaster Forum whost.in - Web Hosting Offers thinkdigit.com/forum/showthread.php?t=109137 TechTin.com Last edited by ravi_9793; 16-05-2008 at 02:39 AM. |
#3 (permalink) |
The Devil's Advocate
ur motherboard is sparkle 8400gs
"The problem that shows up with the three red lights on the console is a complex interaction with some very complex parts.” - Robbie Bach http://beingmanan.com twitter: manan | Last.FM: manan |
#4 (permalink) | |||
evn im manan..!! nehw my motherboard is nvidia 7050..ive made a correction..!! thnks. Quote:
it doesnt show the lan card driver in the device manager..! i ll try the same trick bro..! Quote:
bt evn nw thre is no lan adapter in the device manager, thre is only network adapters.. and in tht i hv remote usb ndis device...wen i chose to update the device it says it is already updated.,,,,and as and when i remove my usb i get discnnctd frm the internet,,!! what do i do? also...im nt getting sound out in my speakers..! the speakers seem to work fine, the wires are connected properly(ive chkd with evry port), the computer shows tht it is playing a sound file properly and evn the volume is full...bt still im nt able to get sound,,,!! what cud be the reason..? Last edited by magneticme200; 16-05-2008 at 08:18 AM. Reason: Automerged Doublepost |
#5 (permalink) | ||
heheh
PS: i think the problems you are facing are primarily because of drivers, get your motherboard driver cd and re-install all drivers, if ur cd does not have it, then call ur hardware vendor and tell him that u need the drivers
#6 (permalink) |
TechTin.com
Can you see any device with "?" OR "!" mark in device manager??
www.9zap.com/forums -> Indian Webmaster Forum whost.in - Web Hosting Offers thinkdigit.com/forum/showthread.php?t=109137 TechTin.com |
#8 (permalink) |
TechTin.com
I cannot open the image. This Digit forum has lots of problem. Please upload somewhere else, like imageshack.us
#9 (permalink) |
dude whatever ! are there means improper drivers, go to ur hardware vendor and tell him to give u proper driver cd, or go to the website and download, or right click on the ! and select the update driver option.
#10 (permalink) |
http://img403.imageshack.us/my.php?image=capturecf6.jpg
here is the link..!! |
#11 (permalink) |
update the ethernet controller
#12 (permalink) |
TechTin.com
yes..LAN card is not properly installed. "Ethernet controller" is having ! mark. You need to install it. Download its driver from manufacture's website.
#13 (permalink) | |
and hw do i determine the manufacturer of the ethernet controller..??? also can u see any problem with sounds...coz im nt getting sound as well... i hv 6 ports behind the cpu fr connecting the speaker wire...which colour shall i go in for?(in case thrs no softwre prob...and i hv cnnctd the wire in the wrong port...though ive tried it in evry port..) |
#14 (permalink) | ||
TechTin.com
It is a type of network technology for local area networks.
#15 (permalink) | |||
#16 (permalink) | |
#17 (permalink) |
TechTin.com
from manufacturer's website.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| LAN Driver | Krazzy Warrior | Networking | 7 | 12-03-2009 02:05 PM |
| Driver | papai_mcc | Hardware Q&A | 2 | 20-07-2006 07:24 AM |
| Where is my Driver ?? | i_hate_computer | Software Q&A | 4 | 04-01-2006 02:40 AM |
| Driver available ????????? | sagargv | Software Q&A | 11 | 06-09-2005 01:12 PM |
