Old 14-05-2008, 11:48 AM   #1 (permalink)
rajwansh2003's Avatar
Default Problem !!!!!!!!!
I have two problem in my PC.
Config. Windows XP prof.
1GB RAM,Core 2 Duo E4500,160GB HDD
PROBLEM:
At startup two problem shows on the screen says
1.This application has failed to start because PROPSYS.dll was not found. Re-installing the application may fix this problem.
2. Visual Task tips has encountered a problem and need to close. We are sorry for the inconvenience
Anupam
rajwansh2003 is offline
Old 14-05-2008, 11:54 AM   #2 (permalink)
Default Re: Problem !!!!!!!!!
Visual Task Tips is a lightweight shell enhancement utility. It provides thumbnail preview image for each task in the Windows Taskbar, as seen in the Microsoft Windows Vista.
uninstall it in safe mode
as for PROPSYS.dll, search for it to find wherer it is located in the PC, get a copy from afreedll.com or from your XP disk and copy to relevant location...
realdan is offline
Old 19-05-2008, 06:28 PM   #3 (permalink)
problem not solved. a new problem.........
should i format my pc.
propsys.dll in this case it say it not right file
Anupam
Old 19-05-2008, 11:43 PM   #4 (permalink)
dhanusaud's Avatar
not need to format ur os...just install a program named "Ccleaner" provided in every month's digit's cd/dvd. click on tools->startup & remove unknown startup programs.
clean registry, & then restart ur system....it will work fine.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
- by chris
