I would like to know if it is possible to directly connect two PCs using a Cross Lan cable but with a following constraint
One PC is on WORKGROUP and is Home PC
Another is a Laptop which is otherwise on a Domain with userid/password i.e. I can not change any network setting here except at the max can assign one 192.168 series IP Address to this laptop.
I tried it… Lan connection shows connected status on both systems but I can not see the each other in the network places.
Thanks..
if both are showing lan connections and both reply on ping then u just need to share ur folders and allowing file sharing option to share files two pc's
KHAO PIYO TE AISH KRO!!
http://twitter.com/puneetshrma
