Old 10-05-2008, 09:21 AM   #1 (permalink)
mannuforall
mannuforall's Avatar
Question XP SP2 Setup Problem-need quick help!
My system: Intel 2.66ghz, 256ram, 845 mb, 80gb sata,
I've XP SP2 installed in, but after a virus attack, I delete virus files detected by avast 4.8. But when restart my system it unable to boot. So I decided to reinstall XP. I delete old XP and format c: then install fresh XP.
NOW problem is that when it reached on 'Installing Device Drivers' or near, system stop responding and stop at this point. I try with another cd but it same.
Plz help...
Manojr Tiwari
http://www.mannuforall.in
You can also contact me for any UC Browser related info.
mannuforall is offline
Old 10-05-2008, 10:03 AM   #2 (permalink)
dhanusaud's Avatar
Default Re: XP SP2 Setup Problem-need quick help!
optical drive problem!!!!
change your optical device & insert XPCD, restart install, it should work fine. if you are sure that you don't any virus in your system left behind then try repairing instead installing.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 10-05-2008, 11:57 AM   #3 (permalink)
rajat22's Avatar
Talking Re: XP SP2 Setup Problem-need quick help!
Try re-formatting with NTFS. Check the optical also.
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
Old 10-05-2008, 05:33 PM   #4 (permalink)
mannuforall
Thanks to all you. After using a new optical drive the installation is now complete successfully. Thank a lot specially dhanusaud.
Manojr Tiwari
Old 10-05-2008, 07:12 PM   #5 (permalink)
dhanusaud's Avatar
heartly welcome
problem in opera quick search dhawald Internet & WWW 1 27-06-2006 07:50 AM
Quick Launch Problem __Virus__ QnA (read only) 14 09-01-2006 11:52 AM
Problem in nokia 6630 while installing quick office maximus_3007 Buying Advice 8 23-10-2005 07:18 AM
QUICK HEAL THIS PROBLEM prajesh QnA (read only) 3 24-04-2005 10:24 PM
Serious graphic problem...need help quick...desperate teknoPhobia QnA (read only) 2 28-12-2004 03:56 AM
- by chris
