Uninstall it from 'Add/Remove Programs' in the Control Panel if u r using XP. In Vista, u'll need to 'View installed updates' to find IE8's entry. Is it not visible there??
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
^^^no it's not in the add/remove programs..........i deleted the internet explorer folder in program files and reinstalled ie7. But now it says some file is missing. i feel i have screwed things up!!
You should never delete IE folder from program files folder. Restore your windows.
Hi friend,
It is impossible to uninstall and reinstall IE fully because that is a part of windows os only thing we can do is some sort of repair technique. In you case i think you have delted some system files and you need to repair the os with a cd to work further.
