Old 04-05-2008, 02:47 PM   #1 (permalink)
speedyguy's Avatar
Default Virus Attack: plz help formating my partition
every log on to windows i get a msg "dont play stupid with me, m better at it"
i hv 4 drives....other 3 drives i formatted but windows partition i cant...
wen i use xp boot it fails 2 setup....otherwise i cant format it 2 get rid of virus....m ready 2 re-install xp but how...setup not working
any way 2 format d windows partition???
Enjoy~!
No Pain...No Gain
speedyguy is offline
Old 04-05-2008, 05:20 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: Virus Attack: plz help formating my partition
^^ if setup is failing (i guess that u are booting from XP CD and then it fails) and u really are sure to format it (instead of scanning ur DRives using a good AV like NOD32)...
So, u hv a n option of connecting ur HDD along with a friend's HDD and then format ur HDD Drives (i hope u got wat i meant to say), coz wen u connect ur HDD along with ur friend's HDD then all ur drives will be listed then u can select ur drives and format them.
BUT, be AWARE! SInce the virus is a irritating one, it may migrate from ur drives onto ur friend's drive too (once u connect in parallel i.e together with ur Friend's HDD) so b4 that, install a good AV, say NOD32 on ur friend's PC then do the above said..
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 05-05-2008, 11:46 AM   #3 (permalink)
Simply, get a DOS bootable CD-ROM & boot from CD-ROM once at DOS prompt simply format c: giving below command
format c: /s /u /v
Once formating is done boot thorugh XP bootable & install it.
Start posting after 1 hour on this forum
Janki
PS: Once all done don't forget to run Acronis & Save the Image file. Will help you save your time next time for such small problem.
janki2008 is offline
Old 06-05-2008, 12:40 AM   #4 (permalink)
Wise Old Crow
blueshift's Avatar
Is that the only effect of the 'virus' or you notice something different with your everyday computer avtivities?
If you have any knowledge of Registry Editor then I won't suggest you formatting.
http://twitter.com/blueshift155
blueshift is offline
Old 06-05-2008, 01:57 AM   #5 (permalink)
tell us the registry editing method blueshift
it might be useful for us
http://thenamemanish.blogspot.com/
mind021 is offline
Old 06-05-2008, 08:57 AM   #6 (permalink)
Wise Old Crow
blueshift's Avatar
^ I mean reinstalling the Windows is not the first step u do.
Most of the Trojan viruses adds entries into registry..So its good to use Antivirus or look into the registry.
btw he didn't tell more about virus.
Old 09-05-2008, 08:38 PM   #7 (permalink)
speedyguy's Avatar
ya i did d boot cd option....i re installed coz i anyway was thinking of it...virus didnt had any other major effect but ya it did slow down d pc.....deleted d windows fonts n some other system files as i observed missing codecs while playing certain type of vdo files.....etc
Enjoy~!
No Pain...No Gain
virus attack nims11 Software Q&A 8 04-05-2008 05:41 PM
Virus Attack skippednote Software Q&A 3 11-02-2008 03:34 PM
Virus Attack ruthless Software Q&A 17 24-04-2007 08:54 AM
A virus attack?? Manshahia Software Q&A 5 15-02-2007 09:37 PM
Virus Attack FasTrack Software Q&A 14 06-11-2004 12:11 AM
- by chris
