02-05-2008, 07:06 PM
Stay Silent!
Ctrl + Alt + Del not working
Hi frnds,
Attached image shows the screen I get after pressing CTRL + Alt + Del.. Theres no menubar.
What could be the problem?
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
02-05-2008, 07:45 PM
Re: Ctrl + Alt + Del not working
Generally this is effect of virus. Scan your PC in safe mode with well updated antivirus. And see the if there is any effect..
Another way is:
1) Run Scan with "Hijack This"
2) Look for anything close to this O17 - HKLM\System\CCS\Services\Tcpip\..\{78B44176-C987-40AA-B09
3) It shoud be the same all the way to this^ point (the numbers may be diffrent
4) Check Mark it
5) Click on Fix Checked
6) Close the application & restart your PC
see if this trick helps you.
Last Option:
Repairing Windows is the last & best option to get rid of this problem.
02-05-2008, 10:00 PM
Stay Silent!
^^ no such entry
NO virus, according to Avast Home, latest updates.
What now?
I saw me running,
02-05-2008, 10:01 PM
CG Artist
So your Windows task manager is not working?
02-05-2008, 10:08 PM
Stay Silent!
Kind of.
I saw me running,
02-05-2008, 10:31 PM
guys guys ...there is no problem
Just double click anywhere(not inside the white area) to bring it back...
see for example here is my task manager screenshot
lol..i was surprised and shocked by the answers you people gave ...
02-05-2008, 10:34 PM
lol..the same problem was posted in past
02-05-2008, 10:49 PM
i agree with adi007....just double click on the upper end cream coloured portion and u will get the menu back.
03-05-2008, 07:01 AM
Stay Silent!
Thank u so much buddy. Why didn't you come online before, i was so scared of the invisible virus that no antivirus cud find.
lol
I saw me running,
03-05-2008, 08:03 AM
lol
wen u r on windows u hav a reason to get paranoid
03-05-2008, 12:16 PM
lol
Lol...You are welcome...
I just hope that you did not reinstall or formatted the system for this reason..
03-05-2008, 12:54 PM
LOL.....
I was just thinking dat it was serious problem. I hv noticed dis trick before in my PC but forget to keep in my memory..
+1 to adi007
03-05-2008, 01:17 PM
Stay Silent!
Well said.
Not exactly.. i don bother for this thing, but now dunno why the speed is soooo slow..
I've 40GB HDD, with 512MB Ram, system managed Virtual RAM, 2Ghz Intel Celeron.
Original Xp, sp2
And the speed sucks. Is this coz my PC is very outdated?
I saw me running,
03-05-2008, 03:46 PM
Legen-wait for it-dary!
Hey people, how would you bring this effect (hiding menu bar and double clicking to get it back) on a computer that works perfectly?
A reverse question, I know, but this seems verrrryyyyy interesting
03-05-2008, 04:24 PM
Well said.
Original Xp, sp2
Buddy if that's what u call outdated system then what do you call mine..
Pentium 4 2.4Ghz 256 MB RAM....
Yes i am having just 256 MB RAM and i am very happy with my system performance...it's better then my friend system who is having Dual Core and 1 GB RAM...
Sorry i didn't understood your point...
Double click on any area(except the white area) to toggle between menu bar hiding and unhiding...and i didn't understood what u meant by "Computer that works properly"...This can be done on any system...
Reason: Automerged Doublepost
03-05-2008, 07:41 PM
HEY!
Lol man it works! I didnt know this before! Neat, really neat.  I thought this was just some abnormal error as usual  nice, thanks for the info
03-05-2008, 07:59 PM
HEY!
U are welcome..
I use it regularly when viewing my cpu usage..
This small trick applies to every tab i.e, process,performance etc.,
