Old 01-05-2008, 10:20 PM   #1 (permalink)
Keep Up The Good Work
mobilogist's Avatar
Unhappy Please tell me the solution.
i get this error on every restart on my pc recently, now it is regular.
what to do?
tell me the solution please.
My webpage
http://www.bit.ly/vksw84/
mobilogist is offline
Old 01-05-2008, 10:27 PM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: Please tell me the solution.
1.exe is a virus. Search for it and remove all instances. As well as, scan your sys with a good av like kaspersky or Nod32
Nokia N86 8MP
Lucky_star is offline
Old 02-05-2008, 12:43 AM   #3 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
run>regedit
search for all entries of 1.exe and del them...and then restart and del 1.exe 4m hard disk..
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 02-05-2008, 03:24 PM   #4 (permalink)
may be a virus or spyware. go to start ->run->msconfig.exe. then go to start up tab there deselect 1.exe file.and then click ok.
abhijangda is offline
Old 03-05-2008, 06:38 AM   #5 (permalink)
vandit's Avatar
mst probably it wont show up in startup in msconfig...as it is a virus....
but do check it..
vandit is offline
need a solution Saharika QnA (read only) 2 25-07-2007 12:27 AM
C,C++ solution gau_pppu Software Q&A 4 31-01-2007 01:03 AM
Need of solution kumarn_2004 Software Q&A 2 19-09-2006 10:56 PM
Solution for XP sachinbaviskar Software Q&A 10 16-10-2005 05:42 PM
Need a solution rajas700 QnA (read only) 3 26-08-2005 09:14 PM
- by chris
