Old 01-05-2008, 05:56 PM   #1 (permalink)
Beta Waves's Avatar
Exclamation NTFS Problem
Hi all , I have 5 partitions in my hard disk . All of them are formatted in NTFS .... I have installed XP Professional and Vista Ultimate on two partitions ..... Except these two partitions Compression is enabled on all the other partitions .... Now i want to enable compression on these two volumes also ..... Is it ok if i do it on system partition ... will i have any problems ???
I am Back....
Beta Waves is offline
Old 01-05-2008, 06:08 PM   #2 (permalink)
God of Mistakes...
Garbage's Avatar
Default Re: NTFS Problem
To enable compression on a partition....
Right click on that partition's icon from my computer.
In General Tab, check the box "Compress this Drive to save Disk Space".
(It's below graphical representation of partitions used / free space)
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 01-05-2008, 06:12 PM   #3 (permalink)
Beta Waves's Avatar
Ya i know how to enable compression ... I asked is it ok to enable on a system partition ....
I am Back....
Old 01-05-2008, 06:17 PM   #4 (permalink)
yeah, a minor performance hit, thats all u gonna bear
Faun is offline
Old 01-05-2008, 06:19 PM   #5 (permalink)
God of Mistakes...
Garbage's Avatar
AFAIK, you shldn't have any problems enabling compression on System Partitions.
Garbage is offline
Old 03-05-2008, 05:25 PM   #6 (permalink)
Beta Waves's Avatar
Bizzare thing happened after i compressed my windows XP partition .... Instead of Used space decreasing it actually increased by 1.5GB !!!!
Then after a reboot it became 1.5GB lesser than my first Used space value ... Now its compressed ....
i have observed one more thing if you compress a software or a game folder .... The reduction is very large ... But it is not that much for audio vedio files .... It is hardly any compression at all
I am Back....
Old 03-05-2008, 05:37 PM   #7 (permalink)
Hey I want to New problem over period of time;
1. If virus infected, is it easy to solve.
2. OS failed (eg. Boot sector problem etc)
3. is backup use ghost etc can be used.
gcbeldar is offline
Old 03-05-2008, 05:40 PM   #8 (permalink)
Beta Waves's Avatar
1.Dont hijack others thread....
2.Post something if you have anything related to the thread topic
I am Back....
Old 05-05-2008, 09:45 AM   #9 (permalink)
Sorry,
I made it here, so that it will useful to many.
gcbeldar is offline
Old 06-05-2008, 03:10 AM   #10 (permalink)
Beta Waves's Avatar
Sorry,
Its ok i am sorry to ... i was rude .... ... anyway with NTFS partition you can do everything you mentioned ......
I am Back....
amaroK NTFS Problem ! Zeeshan Quireshi Open Source 6 01-08-2006 08:37 PM
Fat32 And Ntfs Problem? rakeshishere QnA (read only) 3 03-07-2006 11:14 PM
NTFS Premission problem valtea QnA (read only) 1 27-05-2005 01:19 PM
PROBLEM WITH NTFS AND FAT! stone cold QnA (read only) 11 06-11-2004 01:16 AM
Problem Mounting NTFS partition on Red Hat 9.0 Moin QnA (read only) 10 16-08-2004 11:42 PM
- by chris
