Old 30-04-2008, 12:15 PM   #1 (permalink)
Default How to find the sound driver?
My cousin has got IBM thinkpad laptop...Since he had full of virus in it...I formatted his com....Now i dunno how to find the sound driver and graphics drivers for the laptop?..please any suggestions?
roonie is offline
Old 30-04-2008, 12:24 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: How to find the sound driver?
which model? check at lenovo.com
desiibond is offline
Old 30-04-2008, 12:30 PM   #3 (permalink)
I dunno which model it is...is der anyway to find out?...As far as i know it is pentium 3 old 700mhz..
roonie is offline
Old 30-04-2008, 01:27 PM   #4 (permalink)
Firstly, one of the best question would be happy to answer
You can use the tool Everest Corporate Edition It will show you all the hard-ware parts mfg details of your laptop, so that you can accordingly visit the mfg web page & d/l the drivers.
The above tool is a must for all Hardware Driver problem where we don't know the make or model or mfg. + In some cases in Laptops even if XP detects the driver the hardware doest not seems to work properly so in that case we can know exactly what part or mfg is & accordingly d/l the drivers.
A must have tool for all of you!
Janki
janki2008 is offline
Old 30-04-2008, 01:47 PM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
see for every thinkpad, there will be a product ID sticked to the bottom.
For eg, my T43 has 2668-ce3
based on that you get the driver.
one more way is to connect the laptop to internet, install Lenovo system updater and run it. It will search and grab all the latest drivers required.
Old 01-05-2008, 12:57 PM   #6 (permalink)
yea thanks ....My model is 390x...
roonie is offline
Old 01-05-2008, 01:34 PM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
http://www-307.ibm.com/pc/support/si...HY-45XN9C.html
Old 02-05-2008, 12:40 PM   #8 (permalink)
Originally Posted by desiibond View Post
Thanks dude wil check out
roonie is offline
Old 23-08-2008, 02:54 PM   #9 (permalink)
paroh's Avatar
Try Driver Magician
paroh is offline
how to know which sound driver to install ?? Jags Software Q&A 9 02-10-2007 10:26 PM
sound driver ankitsagwekar Open Source 2 12-02-2007 01:11 AM
Driver Find Goldy Software Q&A 3 19-10-2005 01:05 AM
Find my video driver hug_hotguy Software Q&A 4 24-10-2004 03:12 PM
- by chris
