Old 29-04-2008, 08:17 PM   #1 (permalink)
047
047's Avatar
Question how to unhide system folder help !!!
Can anyone plz tell me how to unhide a folder whose HIDE attribute is disabled?
actually i had virus in my pendrive and it made my folders hidden. when i tried to unhide it the hide attribute was disabled. Plz tell me the solution to unhide the folder.
thanx
047 is offline
Old 29-04-2008, 08:33 PM   #2 (permalink)
Default Re: how to unhide system folder help !!!
try this go to command prompt
start--->run--->cmd.exe <enter>
you'll see a black screen with cursor blinking
go to the drive where you need to un-hide folders suppose your pen drive is L:
so you'll type below things
L: <enter>
attrib -r -h -s *.* <enter>
That's it. Did you see the folder ?
Let us all know.
Janki
janki2008 is offline
Old 30-04-2008, 02:37 PM   #3 (permalink)
Cool Buddy's Avatar
In windows explorer on the menu bar click tools> folder options. now go to the view tab, scroll down a bit in the advanced settings list, uncheck "hide protected operating system files", click apply. Thats it.
Cool Buddy is offline
Old 01-05-2008, 03:02 PM   #4 (permalink)
Tired of being sorry!
quad_master's Avatar
@Cool Buddy
There are 10 types of people in this world, those who understand binary and those who do not.
quad_master is offline
Old 01-05-2008, 10:43 PM   #5 (permalink)
Keep Up The Good Work
mobilogist's Avatar
i too have the same problem, with my d drive(partion).
it shows that there are some .bat & .ini files are there.
so how can we remove it, it is a virus or something else? please.
My webpage
http://www.bit.ly/vksw84/
mobilogist is offline
Old 02-05-2008, 03:34 PM   #6 (permalink)
go to folder options there in view tab uncheck hide files and folders and also hide windows protected files.
abhijangda is offline
Old 02-05-2008, 07:20 PM   #7 (permalink)
047
047's Avatar
Question Re: how to unhide system folder help !!!
thanx for replies.
but system files are always unhidden on my system.
i never hide them so i can track any change in them.
but the problem is that on my removable drive the folders are hidden and their hidden attribute is disabled so you cant unhide them by using "right click-> properties->uncheck hidden attribute".
now can anybody help?
047 is offline
Old 03-05-2008, 06:34 PM   #8 (permalink)
047
047's Avatar
Red face Re: how to unhide system folder help !!!
Originally Posted by dhanusaud View Post
anything serious abt disable/enable....i get to last point "virus"
anyway if you have well updated antivirus, don't consider you are 100% secure from security risks.
follow these steps...it may solve your problem.
Click Start -> RUN, & type "regedit"
Go to registry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Explorer\Advanced\Folder\Hidden\SHOWALL
Find a key called "CheckedValue"
Double click on it & set the value to 1.
check your problem...if it is solved.
The registry value you told was alredy set to 1. what should i do now?
i got one more problem My system date and time is wrong after starting the system; it shows the shutdown time from the last session when the system is restarted.
plz tell me how to upload screenshot so i can show the exact problem here.
047 is offline
Old 03-05-2008, 08:51 PM   #9 (permalink)
ayush_chh's Avatar
simple........press the 'Print Screen' button on your keyboard, now open MSPaint and goto Edit -> Paste. you will get the screen there now save the the file.
goto http://www.maxupload.com/forum/index.php and upload the image there.....
paste the link here when done...........
and for your other problem...
goto command prompt and then type this
x:/> attrib -h -s -a -r * /s /d
(where x: is drive letter for your pen drive)
this command will remove all the attributes from all the files as well folders in your drive.
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 04-05-2008, 12:36 PM   #10 (permalink)
Cool Buddy's Avatar
the mobo's battery is weak, replace it.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 04-05-2008, 03:46 PM   #11 (permalink)
047
047's Avatar
thanx it worked.
@coolbuddy
where can i find this battery?
047 is offline
Old 04-05-2008, 04:46 PM   #12 (permalink)
Cool Buddy's Avatar
you will find it t any computer shop. If you are not sure how to replace it, consult the forum as I too am not sure. you can also take your computer to the shop to get it replaced.
Nokia 5230 :(
Old 05-05-2008, 09:41 AM   #13 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Google, friends...
http://www.computerhope.com/issues/ch000239.htm
http://www.google.com/search?client=...utf-8&oe=utf-8
dheeraj_kumar is offline
Old 05-05-2008, 10:32 PM   #14 (permalink)
ayush_chh's Avatar
ya there is a small battery ( size of a coin) on the mother board......just remove that and replace it with a new one .you will find it in any computer shop....generally known as CMOS battery.....
PS: if ur battery is weak or discharged then u must get a message at boot time.....and your system time will always reset to 12:00 AM ....if this is what happens with you then changing the battery should help you... if NOT then you might be having some other problem
Old 05-05-2008, 11:16 PM   #15 (permalink)
mobilogist's Avatar
sorry to say that but we are dicussing other thing here ie how to unhide all drive's hidden files by removing viruses etc.
where does this cmos battery arrived here?????
My webpage
Old 06-05-2008, 03:53 AM   #16 (permalink)
ayush_chh's Avatar
^^please go through the thread before posting......
this is his second problem........first problem has already been solved........
Old 06-05-2008, 10:54 AM   #17 (permalink)
Cool Buddy's Avatar
i had heard that if you remove the CMOS battery the bios gets reset and we have to change all the settings once again. is it true?
Nokia 5230 :(
Old 06-05-2008, 02:13 PM   #18 (permalink)
Thumbs up Re: how to unhide system folder help !!!
Yep! All the BIOS customizations will lose....
Old 07-05-2008, 08:32 AM   #19 (permalink)
Just the bios customizations, and most users dont really tweak their bios or anything so it should be okay. Nothing happens to windows or anything.
cannot unhide folders phuchungbhutia Software Q&A 3 15-01-2008 10:02 AM
easy hide or unhide folder gsoul2soul Software Q&A 3 09-11-2007 02:37 PM
how to unhide folders hidden by folder guard?? tango_cash Software Q&A 2 20-02-2007 05:33 PM
virus in System volume information folder Shikhar Software Q&A 3 16-08-2005 08:01 PM
help me 'unhide' the local settings folder... anandk QnA (read only) 1 02-08-2005 08:28 PM
- by chris
