Old 29-04-2008, 04:30 PM   #1 (permalink)
mortal kombat
quan chi's Avatar
Default does changing virtual memory affect the system.
hello friends.
well for this problem spiderman 3 problem.i searched the net and in one forum one of the person there mentioned that changing the virtual memory made some improvement in his system.
therefore i changed my virtual memory in 'c' drive.
initially it was:-min:-756
max:-1512 virtual memory.
and below it was mentioned as
recomended:- 2303.
so i changed it to
initial size:-2300
maximum size:-2302
is it ok. will it do any harm to my system??
please do reply.
quan chi is offline
Old 29-04-2008, 10:06 PM   #2 (permalink)
y2j826's Avatar
Default Re: does changing virtual memory affect the system.
it really affects the system and i always use virtual memory, but if you have enough RAM and your compter works smoothly no need to creat virtual RAM, cuz RAM is always faster then Virtual memory . . .
http://worldofy2j.blogspot.com
y2j826 is offline
Old 29-04-2008, 10:17 PM   #3 (permalink)
TheSaint
NucleusKore's Avatar
Yes it does. I have set my Virtual Memory in my C to double my RAM (2 GB, both initial and final size). I do not fancy the swap file writing to various areas of the hard disk as windows adjusts its size, and getting more and more fragmented. As a matter of fact, some recommend a dedicated partition (yes, even in windows) for the swap file.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 29-04-2008, 11:43 PM   #4 (permalink)
mortal kombat
quan chi's Avatar
well sorry but its still not clear yet. .will it harm my system.
quan chi is offline
Old 30-04-2008, 12:53 AM   #5 (permalink)
Genius in making mistakes
bhushan05d251's Avatar
Choose "System Managed Size" in the Virtual Memory's option window......
bhushan05d251 is offline
Old 30-04-2008, 07:12 AM   #6 (permalink)
TheSaint
I think it is clear
1. Set the virtual memory as you have above, but make sure it's double the amount of ram you have (you haven't mentioned how much ram you have?!)
2. No point of making 2300 and 2302. Let both maximum and minimum be the same
If you follow these two guidelines you won't harm your pc. If you don't then I do not know.
Hope it's clear now.
Old 30-04-2008, 07:34 AM   #7 (permalink)
Beta Waves's Avatar
It wont harm your computer if you increase or decrease the size of virual memory... But of course if you decrease it ... You will see a performance degradation while playing resource consuming games and softwares like Adobe photoshop.... So it is better to have upto 2 GB specified ..... And also if you have a separate partition for it ... it is well and good ...
I am Back....
Beta Waves is offline
Old 30-04-2008, 11:12 AM   #8 (permalink)
pushkaraj's Avatar
I hav heard that if the page file is on a partition of a hard disk other than the one on which ur os is installed then it gives a performance boost. Is this true?
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 30-04-2008, 11:58 AM   #9 (permalink)
Cool G5's Avatar
Post Re: does changing virtual memory affect the system.
True,but preferably it should be on your second HDD.
Cool G5 is offline
Old 30-04-2008, 02:28 PM   #10 (permalink)
Cool Buddy's Avatar
Virtual memory can in no way harm your PC, increase or decrease doesn't matter. Min & Max size should be same, so that windows doesn't waste resources on resizing it.
Having virtual memory on the non OS HDD gives the best result. However today's games & softwares are resource hungry & virtual memory doesn't help much. If you want to boost the performance of your system then increase the amount of ram.
Cool Buddy is offline
Old 30-04-2008, 03:04 PM   #11 (permalink)
mortal kombat
quan chi's Avatar
Originally Posted by NucleusKore View Post
I think it is clear
thanks it is clear. please see my siggy.
thanks guys for replying.as i have 1.50gb ram so according to your comments i have made it 3000 both initial and maximum.
is it ok.
quan chi is offline
Old 30-04-2008, 06:45 PM   #12 (permalink)
TheSaint
That should do, now defragment your C drive
Virtual Memory too low!!! anshul Software Q&A 6 07-02-2008 12:13 PM
Abt virtual Memory? digit i am thinking QnA (read only) 9 15-01-2008 01:41 PM
What is virtual memory? pritish_kul2 QnA (read only) 3 25-06-2007 06:53 PM
virtual memory is low ? mkmkmk QnA (read only) 7 19-06-2006 09:03 PM
Does Changing Of Web Server Affect Listing On Search Engines tuXian QnA (read only) 4 18-03-2005 08:46 PM
- by chris
