Old 28-04-2008, 03:21 PM   #1 (permalink)
smile's Avatar
Unhappy Plzzz help
The problem is strange when i click on search button , i cant view anything , just the dialog box has open and nothing i can find in it..... I have already scanned my system . But still the problem persists Can anyone tell me what is the problem
SR
smile is offline
Old 29-04-2008, 04:51 PM   #2 (permalink)
dhanusaud's Avatar
Default Re: Plzzz help
post ur problem clearly... we don't know which search button you are clicking windows search or web search?
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 01-05-2008, 03:16 PM   #3 (permalink)
Tired of being sorry!
quad_master's Avatar
absolutely!!....problem isn't clear
There are 10 types of people in this world, those who understand binary and those who do not.
quad_master is offline
Old 01-05-2008, 04:46 PM   #4 (permalink)
hey u can try repairing ur windows
abhijangda is offline
Old 02-05-2008, 12:03 PM   #5 (permalink)
smile's Avatar
Its windows search button ie: Start - Search for files and folders
SR
smile is offline
Old 02-05-2008, 02:43 PM   #6 (permalink)
hmm...follow these steps....
Open Explorer and go to the Windows\Inf folder. Locate the srchasst.inf file. Right click it and select Install. You'll need your XP CD or the files from the I386 folder. (This fix will require you to have your Win XP CD).
The Windows\Inf folder is a hidden folder. You can adjust your Explorer Folder Options (View tab) to Show hidden files and folders. You can also click Start, Run and enter %SystemRoot%\Inf to open directly to the Inf folder.
tell me now it's working or not?
http://www.kellys-korner-xp.com
what to doo plzzz help hackers2005.3721 Mobiles and Tablets 3 31-05-2007 07:24 PM
Help me out PLZZZ.... anweshkumar Hardware Q&A 11 08-04-2007 01:00 PM
help plzzz SoulgrinD Software Q&A 2 22-06-2006 08:10 PM
help me plzzz genre_rock Gamerz 3 21-02-2006 11:44 AM
Plzzz Help Me.... eshansinharay QnA (read only) 2 25-09-2004 03:25 PM
- by chris
