Old 28-04-2008, 02:34 PM   #1 (permalink)
jacques's Avatar
Default laptop issue
I am at US onsite. There is a problem that keeps coming in my laptop. WHenever I start my laptop, the mouse pointer start tripping down and it gets struck at the base of the screen. Sometimes it starts tripping up and gets stick to the top of the screen. I have to disable the touchpad and work with my mouse. Sometimes mouse also doesnt help and then if i restart, the problem goes.It keeps happening. laptop is toshiba make. It may be due to some driver error.
please help me ou to resolve the issue
jacques is offline
Old 29-04-2008, 04:53 PM   #2 (permalink)
dhanusaud's Avatar
Default Re: laptop issue
specify your lap model..
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 29-04-2008, 05:36 PM   #3 (permalink)
Is your mouse with cord ? because even on my laptop when i connect mouse with usb cord the cursor tripping left/right.
Solved the problem using Optical Mouse. I am now using Logitech V450 Laser Cordless Mouse it works fine.
Janki
janki2008 is offline
Old 29-04-2008, 06:24 PM   #4 (permalink)
dhanusaud's Avatar
Janki
if computer table has vibration due to system fan or high sound of woofer speakers, laser mouse (even bluetooth wireless) get effects becoz sensor gets the image movements. I too am using logitech bluetooth wireless mouse. sometimes it has movements while my ceiling fan is running in full speed.
anyway, let him to describe wht is he exactly using & lap model as well.
Old 29-04-2008, 07:10 PM   #5 (permalink)
dhanusaud: Since i have practically seen these things on my laptop i tought changeing to optical mouse might help, but all your points are valid as well
Janki
Locate Laptop - locates your stolen laptop! parthbarot Technology News 11 16-03-2008 11:29 AM
laptop issue sushantsaurabh Laptops and Netbooks 4 28-02-2008 01:22 AM
help me finding Laptop review in july issue gurujee Laptops and Netbooks 2 26-10-2007 10:49 AM
Laptop Issue sattumail Laptops and Netbooks 3 01-03-2007 06:16 PM
Laptop Lan Config error work only with laptop not with pc minniawochat PC Components / Configurations 4 19-09-2006 03:21 PM
- by chris
