Old 26-04-2008, 12:49 PM   #1 (permalink)
Default How To open Data Traveller(pen drive) in winxp.
HI
I have a pen drive "king stone Data Traveller 2gb" .when i put it in MAC SYSTEM i can open all the files and folder inside it ,but in win xp it says "the disk in drive in E is not formated ,do you want to format it now ?" Then I clik on yes,
then it shows "there is no disk in dirve E. insert a disk and then try again.
so it is not formated by win xp and also never shows any files.
If any body has solution for it then please help me out.
suraj is offline
Old 26-04-2008, 04:37 PM   #2 (permalink)
Default Re: How To open Data Traveller(pen drive) in winxp.
What is the format of the drive. Windows can read FAT and NTFS
ThinkFree is offline
Old 28-04-2008, 09:19 AM   #3 (permalink)
I did format in both NTFS and FAT system , but it still not formated.
suraj is offline
Where can I download Drivers for Kingston 1GB Data traveller for Win 98 SE? ajayritik Software Q&A 1 15-12-2007 07:15 PM
Install WinXP from USB Drive a_to_z123 Software Q&A 1 07-04-2007 12:59 PM
Default action is now Search instead of OPEN (winXP) Ricky Software Q&A 1 09-12-2005 12:19 PM
MDAC (Microsoft Data Access Components) on WinXP SP2 g_goyal2000 Software Q&A 1 07-12-2005 10:53 PM
installing winxp on win98. Any problems to existing data..? tkprakash Software Q&A 4 29-09-2005 10:22 PM
- by chris
