Old 24-04-2008, 08:23 PM   #1 (permalink)
Default coreldraw starting problem
I have installed coreldraw X3 on my PC which has Windows XP with service pack2. When I click to open a new file or an existing file my CPU usage becomes 100% and it takes 3-5 minutes to open. Can some one help me? I have tried reinstalling the software but it didn't help. After corel starts there is no problem. It works smoothly.
amitkumar is offline
Old 26-04-2008, 12:52 PM   #2 (permalink)
dhanusaud's Avatar
Default Re: coreldraw starting problem
generally it slows down PC while creating & loading corel environment. me too was facing the same problem few months ago. upgrade some memory resources, it will definitely work fine. also remember while running corel x3, confirm there is no other application running.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
starting problem kunaltech Hardware Q&A 8 08-03-2007 10:45 AM
Do any One Has a Genuine CorelDraw Software............? satyamy Software Q&A 4 16-10-2006 11:40 PM
FAR CRY Starting Problem reddick Gamerz 12 20-01-2006 08:10 AM
Can it be done in PhotoshopCS or CorelDraw sms_solver QnA (read only) 6 27-05-2005 10:43 PM
- by chris
