Old 23-04-2008, 05:01 PM   #1 (permalink)
ayushman9's Avatar
Exclamation Help in Rasdial
I am using Windows vista ultimate 32 bit .I wanted to make a batch file using rasdial to automatically connect and disconnect . After searching from net ,i was able to make a batch file which can successfully disconnect the net connection .
However i still cannot make it to connect to net .My ISP is Dataone ,home 500 . Please help ?
There is No Dark & Light side of Force . There always has been,always will be & always has been,One & Only Ayushman
ayushman9 is offline
Old 23-04-2008, 06:40 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Help in Rasdial
I posted this I believe.
rasdial connection_name username@dataone password
save it in a bat, and run.
I'm busy now, I'll write that tutorial later.
edit: i forgot the connection name sorry
dheeraj_kumar is offline
Old 23-04-2008, 11:44 PM   #3 (permalink)
ayushman9's Avatar
Smile Re: Help in Rasdial
Thanks thanks however your format is wrong there is no "@Dataone" Once i removed it i was able to successfully run Rasdial . I was also able to schedule by including in auto shutdown
Thanks again mate . You helped me sleep in night .
Old 24-04-2008, 05:16 PM   #4 (permalink)
No, I'm quite sure you have to include a "@dataone" in the username, because thats how BSNL assigns the usernames. Wait, is it different in your location or something? Because thats how it is in Chennai here.
Problem with rasdial.bat file joey_182 Software Q&A 2 04-03-2007 02:44 PM
- by chris
